Lemania ??
Not really. If I had gone to aliexpress I probably would have found them at 50 for $5 but I just spent 2 minutes on ebay instead because it is easier to wade through. But day to day right now, nobody ever knows what we're going to be paying for this stuff. Interesting! I just assumed I would mostly be using 0.2 or 0.3. I'll have to dig around for some guidance on how to sharpen them but don't wish to drag this topic further afield.
I've used these in the past it's just a case of having the right chuck.
By Michalzeszen · Posted
Ah so it is an active system. Both holes are in use (hehehe). Interesting. -
Thanks again. I hope to be able to source a fly in the next few days, but if not I will get back to you. Dell - that is a really helpful offer. Repivoting would be well outside my comfort zone. I live in Essex - almost another country, but not quite!
I see now where the plate is worn which would cause the wheel to tilt. Depending on the movement and how much you want to put in to it the easy fix is a new plate. The other option I've done in the past is to insert a piece of metal where it's worn. Schneider Electric_iPF-iPRD_A9L08501.pdf
