Balance staff haul
Eyup everybody hope you are all well and having a great day. Mine is so far. For those of us that are new to watch repair ,have you ever seen so many balance staffs in one place? Approximately 3000 different calibres 😶.
I am going to busy for months sorting this lot out but I'm happy about that. Again the universe is looking after me, seems its giving me some sort of mission.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
