Mentioned in another thread that I've just picked up an old National rotary cleaning machine.
I've noticed in some professional watchmaker videos that they put the complete balance back onto the main plate and put it through the cleaning cycle. Looking at the rotational speed and the cleaning fluid resistance, would this be okay for older watches that don't have shock systems and have old hairsprings? Or am I, as usual, over thinking this? It just seems that we treat the hairspring with kid gloves the rest of the time, then batter it in a cleaning machine.
with modern watches they typically don't like to remove the balance wheels from the balance bridge especially of it has a etachron system of holding the balance wheel hairspring in place. So just easier to remove the balance jewels and clean the balance safely mounted to the main plate.
But with vintage you're cleaning fluid isn't going to touch the pivots or the jewels if they're all sealed up in other words the balance is in place. So it's better to entirely remove the balance wheel from the watch and put it in its own separate compartments in the baskets or in a separate smaller basket. You don't want anything bumping into the balance wheel and hairspring when you're cleaning
10 hours ago, SpringMangler said:
Just so I'm clear, which gets harder the older I get, should I remove the balance from the balance cock before cleaning?
probably before I make a commitment to be nice to have a picture of the watch preferably over the balance wheel. But whenever I clean anything that I can't take the jewels out like pocket watch I remove the balance wheel from the balance bridge and clean it in a separate compartment so the nothings going to hit it and there's no stress on the hairspring hopefully. Sometimes I'll drop the pallet fork in the same place most the time that works sometimes the pallet fork insists on getting stuck in the hairspring I think that happened one time but typically the the pallet fork small I could go in the same container. But there is always that weird tiny possibility that it might decide to lodge itself into the hairspring usually isn't a problem but I'm just giving you a cautionary the balance wheel does best if it's all by itself.
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
