I am working on a Paul Garnier pocket watch. After stripping off everything I could recognise, I was left with two posts that do not seem to do anything. They are not on the dial side of the watch. Photos attached. Any ideas what they are for? Thanks.
that's great. many thanks  I did wonder if they had anything to do with the dial, as I could not find dial screws in the place I expected them. The watch did not come with a dial but  I hope to restore the watch to full working condition as the movement looks beautiful. I will try to source a dial somehow.
