I've just done my fist attempt at a full disassemble and rebuild. Watched the Mark Lovick video tutorial a number of times. Good to go. Ready for the first clean in Lighter fluid. Check everything. Balance secured to base plate. Balance jewels removed from balance cock and plate. Kept separate. Good to go. Jewel spring on cock secured. Good to go.
Place everything in Ultrasonic cleaner. Off we go.
Done it. Feels good to achieve everything. The rebuild will be a doddle.
Put everything out of the tray into a receptacle to dry. What's this extra bit of gold glitter? I did not have anything golden in the tray.
Pantomime. OH yes you did.
I had not secured the balance bottom jewel spring on the base. There it was!!!!!
Easy to put back isn't it? OH no it's not. I've been at it 3 days now. Not skilled enough. Even sent off a set of ss tweezers.
I will get there.
Doing it wrong means you do it right next time.  Will I secure both springs before a clean? You betcha.
Ross
Is it an Inclabloc 'lyre' type spring where you have to get "T" end back in place ?
They seem nearly impossible when you are a beginner - but you will look back in a few years and wonder why you struggled !
One way to make it easier is to put some Rodico at the edge of the block where you are trying slide to spring in.
Stick the spring to the Rodico vertically - you may need to adjust the angle to get it to slide in.
Then using pegwood and tweezers, slide the spring down in to place. The Rodico should stop it pinging off.
It's much easier if you are lucky enough to have a microscope to work under
Yes. Incabloc. I like the idea of the rodico. Job for tomorrow.  I've limited myself to 2 hour per day. Well past that already.
Regards
Ross
Edited by rossjackson01
Spelling
Using the Rodico means you don't have to hold the spring in (wobbling😧) tweezers. You can just push it down with pegwood.
Good luck
On 5/14/2022 at 8:06 AM, Kalanag said:
See this video (8:30 up):
Thank you Kalanag, and to all. Done it.
Been trying for days. Ping, ping, ping. Search for the spring.
Tried it again today. A small piece of Rodico on the spring stuck to the tweezers when I removed the spring from the Rodico. Used that as the holder, placed it against the gap. Closed my eyes and took a breath. Now I'll push it in. What? Don't need to, as it is already in.  Gently push each side of the spring into place. Done!!!
Cleaned the base again. Tomorrow I will try to put the gems back in.
Woohoo!
Ross
Spelling
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
    • What browser are you using Rich? Fine for me using Chrome
    • Wiggle it back and forth, small steps, keeping the pallet cock as level as possible and take your time (!). You could also use an extra tool as a safeguard at the jewelled end to avoid pressure on the pallet fork. You also mention lubrication... On the pallet fork pivots??
