Red 12 .... Conundrum
My Great Grandmother's Red 12 is a long term project for me as I need to learn how to bush the barrel bridge and main plate and try and source a new Barrel/ Barrel lid.
However, by a stroke of luck I have picked up for next to nothing another red 12 movement which matches the case size perfectly. Having cleaned and serviced it, it appears to be running pretty well .... beat error is about 0.9, the amplitude is ± 240 and I can regulate to run -2 to + 8 secs (initial set up only tested face up).
However, the winding stem is broken, and more problematic the keyless works appears to have a separate push mechanism to set the hands.
Firstly does anyone have any thoughts/advice on how I might source a winding stem?
Secondly, does anyone have any clever thoughts on the hand setting? I can open the back (which is a pocket watch style back) and use a screwdriver to activate the hand setting - but is that my only option. Currently I am in the realms of so near ... but so far!
Pictures of the movement attached. There are some numbers on the plate (34731) and bridges, but no movement makers marks.
Edited by LeCorbusier
This would appear to be the kind of mechanism which goes with the movement I have. As I have no intension of installing a pusher of this kind in the case (even if I could), It would appear that this is a non starter.
Still I enjoyed servicing the movement and getting it running again ... you never know, I might find a use for it.
Hey Ho!
    • I suppose this fits "best" in this forum 😃 Im looking for some wall 'art' that doubles as a reference. Specifically Id like to find an ETA 28xx or Sellita exploded movement view. 2824/2836 would be ideal. Have any of you seen/found such a thing - there seem to be a lot of these for specialized movements, and none of them ready to print or to be had as a poster. Why help is appreciated.
    • The diameter is that of the ring - afaik, will have to look it up. “Wiggle room“ doesn‘t matter as long as the spring length is in the ball park.  Essential sizes of a mainspring are thickness, width and length. Diameter is just a hint if you can push into the barrel directly or will need a winder, it is no property of the spring. Frank
    • Hi @Zendoc, I guess you're like me and you don't have a mainspring winder.  I searched GR mainspring for the AS 1686 mainspring and I now understand your dilemma. The exact one is discontinued. To answer you question more directly, I see two good alternatives for you: a) GR4485 with 1.60 x .10 x 280 x 8.5 ( I guess this one is the one you found): https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/GR4485 OR b) GR4477 with 1.60 x .095 x 320 x 9. https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/gr4477   As you know, the the AS 1686 spring is supposed to be 1.60 x .10 x 300 x 9. - both of the above will fit and you'll manage to insert them from the retention ring without need for a mainspring winder (provided you know how to do it). - GR4485 will give you more power (=higher amplitude), but less power reserve (due to shorter length) than the original. - GR4477 will give you the same power reserve as the original. However, a bit less power.   Personally, I'd take GR4477 for two reasons: 1. Well, the power reserve is better. 2. With modern lubricants and modern mainspring metal alloys, you tend to get a higher amplitude anyways. You'd maybe even end up with too much amplitude (knocking) if you go with the original size and use thin synthetic oils-- see discussion here: https://www.watchrepairtalk.com/topic/10580-omega-calt17-help/#comment-248101
    • Your setup is correct. The smallest diameter of one pulley must correspond with the largest of the other one, else not speed variation. Frank
