Hamilton 629 Incabloc Setting Troubles
I'm servicing my grandfathers Hamilton Thin o' Matic, and I went to clean the shock setting when it snapped. I believe this is from having multiple services done on it, causing the metal to fatigue, and partially of course the fact that I'm very much a armature. After trying for 20 minutes to get the setting off it snapped completely, and left the "tail end" stuck inside. I'll show you a picture. I'm used to incabloc settings where the whole piece comes out as a whole and is replaced like wise, so I'm not sure why this one seems locked in place. I'm going to replace the setting of course, however I need to know how to replace it, and take the existing broken piece out. Any help guys? I would appreciate it a lot seriously.
Its a series of task that you need to get good at as they will be often needed , namely ;
Loosen the stud screw, while the cock is still on the msinplate.
Removal of balance with cock atttached " a must "  for any time you service a watch.
Flipping the cock and balance assembly over   ( cock down , balance up)    so to turn the boot of the regualting arm to let the hairspring out of regulator slot. You then poke the stud out and drop the balance ( a soft landing).
Some settings are held in place by a U clip which when removed the setting would easily come out.
Install the shock spring and assembke inreverse order.
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
