I inherited a few projects, the Mustang II watch is for my future father-in-law but the movement is modular (and difficult to get into so I can figure out why it's bound up with geartrain not moving.)
Any background on this? I don't have a clue as to the manufacturer, nor can I figure out how to (carefully) disassemble it from the current state. (Bonus points if you can guess the project watch in that movement photo.)
Second one is a mystery Swiss brand, inherited from a grandparent within the family who passed away at 100 years old. He knew how to value his time, but most of his collection was just cheap quartz pieces towards the end. I don't know anything about this brand, and I also cannot seem to get into the case with a knife. The corrosion doesn't help. This one ticks but I haven't put it on a timegrapher yet and the winding action is a little stiff.
There's a little knife easement in the caseback, but I cannot get any torque on it. Any suggestions? I don't want to break this one trying to get it open.
Thanks all! I've learned a lot in a short time working on HMT movements (similar to 60's Citizen 17J movements) but these two have me a bit dead in my tracks because they mean more than the throwaway watches I have purchased to disassemble and learn on.
Edited by Barsomn
Typo
The movement looks like a Baumgartner 582 'digital: http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&69&2uswk&Baumgartner_582_DIG
Onto the second watch ... should be interpreted as 'Diantus' rather than 'Diantvs'. If you there google something like diantus watch history you should have more luck.
For some case openings I have a normal screwdriver (with a good quality approx. 4mm steel blade) I filed down to thin the blade but still keep it's width. This is ideal for then putting in the opening recess and then a twist of the handle easily pries the case back off. I find this more reliable and controllable for where there is an opening recess than a more traditional case knife that can slip or not apply such even pressure.
Thank you for your replies WatchMaker!
Especially on the Baumgartner, you are right on the money. I may get bolder in attempting to disassemble it or at least separate the movement from its' caseback.
I did try that after making my post and found it's pretty common, and still exists under the Swatch Group.
Diantus Watch Ltd. - Swatch Group
I work on cars a lot, so going for a small screwdriver with a quality blade seems like the best bet. Was recently burned by an HMT Sona case with a particularly difficult caseback so trying again with a fresh perspective may be all that it takes. 🙂
I was able to get the Diantus caseback off. Thanks @WatchMaker! It's the pin-lever single jewel EB8800 movement, as anticipated. That one should be relatively easy to service or source spares for. I'll add pictures eventually.
Trying to get the Baumgartner apart and determine why it is locked up or source a whole replacement movement for, next.
Hi @Barsomn - ah great; glad that worked. Thanks for letting us know. Any engineering, watch repairs included, need some satisfying bespoke tools! 😀
The EB8800 came in different varieties from zero jewels to 21 jewels. The most common problem on the more basic versions with no shock protection is a broken balance staff pivot. Someone years ago could have accidentally dropped the watch or it had a sharp knock, a pivot sheers and that puts paid to the watch working.
So this would be the first thing to check: with any residual power taken out of the mainspring as per normal best practice then remove the balance and inspect the staff pivots. Bent? Sheered off? You'd be best off sourcing a balance complete or working donor movement as without the right tools, balance staff replacement isn't for the novice. Or you might fancy a challenge of course. 😉
If the pivots look straight and intact then the movement may just need a good service.
Always an adventure, but the correct tools make the job much easier @WatchMaker. I hope to grow out my arsenal of good hand tools, etc. and come up with smart ways to do the rest (cleaning, paint or lume work.)
That's true, I was wondering what could be bad if it runs for several hours and then stops or if it's just in need of a service. You make a point on bent vs. sheared balance staff. The timegrapher reading is all over the place but mostly negative, looks like a proper snow storm.
I thought if the balance staff broke you were pretty much dead in the water, but it could just be ever so slightly bent from a hard knock.
The EB8800 movements are relatively cheap and plentiful. It looks like I might actually be better off buying a running example than just the movement alone. Wondering if it would be better to replace it with one that has more jewels (as opposed to just the one on my balance.)
I'm sure it's a common theme where I feel bad taking a watch apart that is running to fix one that isn't running, but that happens a lot with cars too. I'm fairly comfortable replacing a balance after working with those vintage 17J movements, so long as I do not stress the hairspring as I'm not good enough to manipulate it back into shape. I'll admit.
Donor movement for the Mustang II watch project comes in this week too! I believe it should be here by tomorrow.
Once I have some more time, I can finally add photos to this post. Need a day set aside for my projects to break the tools out again and get to work.
Yup.  I have been facing this with Vulcain Crickets.  I finally got a donor that had enough wrong with it that I will JUST use it for parts.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
