Mystery Watch.
Or nearly. I got 2 not working ladies pocket watches from my dad.
These belonged to one of my great great granddads wife's (he was married twice),so 50% chance it belonged to my great great grandmother.
I thought I had a photo of this one before I took it apart, but I must have deleted it I'm afraid.
On the inside of the case, it's stamped "fine silver" with a crown above it. so from what I've read, it's either silver plate or 99.8 pure silver?
It's also stamped with "A.T". Looking this up, it's a makers stamp, of a silver Smith who made watch cases. A Alfred Thickbroom of Galway street, London. He worked between 1833 and 1866, died in 1877. So that's interesting.
The movement has no makers markings on it, apart from the number 8216. I read that at that time there were little workshops making the movements and not signing them?
I stripped the movement down apart from the mainspring housing,,looks a bit complicated, so will leave that for the future. The mainspring is working ok anyway.
Apart from being dirty, the balance spring had looped around the outside of the regulator arm. I eased that back into the right place and gave all the parts a clean in lighter fuel, then reassembled it and oiled it. All good, it now works, ticking away like a good one.
My main question is, the dial is very dirty, in the photos it looks out of shape and cleaner, put that's just the camera angle doing that.
I've tried soapy water and a cotton bud, but it hasn't touched it. Is there something stronger I can use?? Hopefully without damaging the gold around the edges. Would be nice to clean it up a bit.
A little bit of a family heirloom I guess, so would be brilliant to get it restored to its former glory again.
Mark.
A
I use a special silver cleaning cloth for watches of this style and era - they're soft and impregnated with special fluid for precious metal cleaning. Try rubbing the dial very gently with a cloth like this to see what the effect is. The cloth will also clean the case nicely and give it a real sheen.
The case reminds me of a J.G. Graves English Lever watch I once had - but the movement is different.
Thanks guys. Willfly, the silver polishing cloth, is it the Town Talk polishing One? Or a similar type.
Haven't had the pleasure of seeing a lever watch yet.
Never thought of using baby oil, does that act as a mild clearer bob? Interesting to know.
I don't know Ken, the actual movement had no makers name on it, just a number, so that's a mystery.
Hi badger,
I believe baby oil will remove/lift oil based dirt which is difficult to "dilute" in soap and water. Then it will also "hydrate" the old material used on the dial (probably not enamel). In any case, it will refresh the old colors and make the whole thing shine, overall. Then the soap and water will remove any excess. It is not 100% but it works on many dials. I've even let it as a final stage in cleaning and won't harm anything (use sparingly though).
Hope it helps,
Bob
Thanks Bob. Think I got some baby oil around here somewhere,so I'll give that a try first as it seems a bit more gentler, see how it goes. If not Will give the silver cloth a careful try afterwards.
Mark.
Hi Bob,  Baby oil is just a highly refined hydrotreated mineral oil with a samall amoount of perfume and maybe glycerin added.  The oil is also known as liquid paraffin which you may be able to source at a chemist.  Being highly refined it will not have much 'solvency' so may need time to work.  You could also consider BBQ lighter fuel which is basically de-odorised kerosine but has better solvency (a similar product is used for rolling aluminium into foil for cooking foil).
However, I'd be reluctant to use either on a dial unless it is a ceramic/porcelein dial in which the characters are also likely to be permanent in the glaze.
I see your point canthus. I think kerosene is a bit too much for dials though. The idea of baby oil, if I'm not mistaken, is to lift dust and other "impurities" (or float them if you will, being of higher density than water).then the soap and water does away with the residues and oil itself. It is done gently and sparingly. As usual, it doesn't have a 100% success due to the differences in dial construction. In any case, I've used it with a certain degree of success as well as soap and water by itself and dial brushes/rodico. No system I've used/seen/read/heard about dials is a complete solution so experimentation is always the first approach. Whatever the situation is, I'm in quite a receptive state on this topic!
Cheers,
Bob
Hi Bob
See your point re floating off the muck.  Assume this 'sticks' to the oil.  Just a point though the oil will be lighter (less density, about 0.85 v water 1.0) and so will float on the water. This is why kerosine and lighetr fuel are good dewatering agents.
    • I can't see anything under where the balance sits, anything on the dial side?
    • Ok so banking pins are not always perfectly straight and it may have been set this way on purpose, possibly even at the factory. There are various checks to be made before attempting any straightening up of them. At this stage i would carry on as you are, the banking positions will either be right or wrong so deal with that when the time comes. Your first step in having to replace the pallet fork is to correctly identify the movement you are working on Dave Do you know how to do this Dave ?  Pandow is only a watch co. name, not the name of the movement maker.
    • There were many variants of the bezel lock and crown for the Weems. Usually there was a crown and a wedge part that prevented the bezel from turning when locked. The 2 o'clock position is the look I am going for... ...but the unit I'm trying to restore to function was held together with one screw wedged inside the case tube and screwed into the crown. The crown turns freely, unfortunately and would not lock down the bezel....   There was no wedge piece and this set up served only to keep the crown with the watch. Losing these parts was all but assured and replacements are nil. I've built the wedge part but I'm wondering if anyone knows how these were supposed to work originally as I cannot see the best solution? The tube is threaded as if there was a stem threaded to the case and a tip that threaded to the crown? As it stands the crown/screw combo I have is .80 and the screw head is 1.80.
    • https://www.partinfo.co.uk/docs/11671
    • I found a 1998 Timex quartz diver digging through a briefcase of $10 (3 for $25) watches on the first Sunday of June (8 days ago) and found this crudy scratched timex that you could barely read the dial. It was missing an end link on the bracelet. I was able to source a new mineral flat and a pair of end links. The dial has a couple of semi circular light scratches hardly noticeable and needs a new crown and polishing of the bracelet and case. But overall I really am taken to this piece. The bezel insert shows some damage. I think the guy who owned this mixed cement a couple of times and then threw the watch into a drawer when the end link pin broke. The hands are immaculate and no water ingress has occurred. Still need a couple of things to do but I like the old scratched bezel offset by the new crystal and almost mint dial and hands. It seems to be running about a second a day or less fast. It's 40mm and 9.7mm thick. 47mm lug to lug. I like that it is not too thick and the reading of time is instantaneous!
