Hi,
I bought a Boley 8mm lathe on eBay which came with some ring and step collets but unfortunately they don't fit the lathe. Judging from appearance they may be from 2 different manufacturers. They don't have a makers name and I hope they will look familiar to someone?
Thank you.
How is that they do not fit?  Do they not fit at all into the spindle?  Do they fit in the spindle, but only so far?  Do they fit all the way into the spindle but do not interface with the draw bar?  Do the threads fit the draw bar when outside of the spindle? Can you show a measurement of the diameter of the collet?  Is there a key in the spindle but it is too wide for the key clot?  Have you fit a standard collet into the spindle?
My computer does not work.  What is wrong?
Edited by LittleWatchShop
I've come across a few ways that a collet might not fit.
The collet might be the "long" type, where after tightening the drawbar all the way, it's still loose. This can be solved by putting washers on the drawbar until the collet can be tightened.
Another way is the collet is too short that the drawbar cannot engage the threads. It might be possible to lengthen the drawbar or buy a longer drawbar.
Thirdly, the threads might not fit. I'm aware that China made lathes use a different thread pitch for their lathes. Although it's also 8mm, they won't fit a WW 8mm lathe. I'm not sure if buying a China made drawbar will solve this problem.
Good luck!
Thanks both.
One of the step collets is just too big to fit into the headstock. It measures 7.8mm diameter at the level where the slot starts compared to 7.75mm at the same place for the Boley.
The other 2 step collets fit into the headstock but the drawbar / spindle only will only tighten half to one turn. The screw gauge on both collets is 40 Whitworth (same as a Boley collet). But the external diameter at the threads is 6.99mm compared to 6.83 of the Boley.
Maybe a Chinese drawbar would work. I tried looking on ebay but could not find one...
Great thanks. Also if you search 'adjustable drawbar' there is Chinese one with a metric thread one end and WW thread the other end.
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
    • Hi,  I have this vintage Navitimer 806 with a bezel that plays a little bit as shown in this video: https://imgur.com/a/2NjdiF0 How would you fix this? I don't see where a gasket would fit for instance. Also, it seems this issue happens sometimes with older Navitimers.  Thanks
    • This is a screenshot of a video of it running. Not the best quality, though.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers. Then to go with this, watch manufacturers change their minds about which oils to use more times than actresses change their knickers.
