Got this on Ebay...more amusement for me and practice (as if I don't have a ton of watches here already in the queue).  It is fun to work on something I am familiar with.  This is no doubt the simplest watch I have worked on since there is no sweep second hand to deal with.
It was pretty froze up.  I guess oil dried up in the barrel.  I had to manually let the power off with a screwdriver as the mainspring could not overcome the friction.
Anyway...disassemble and cleaned the proper way.
Always my biggest challenge for these non-shockproofed watches is the reassembly of the balance wheel after removing it from the cock in order to remove the cap jewel.  Extremely tedious and very time consuming.  Hey...I am an amateur...have not learned the tricks to making this easy...give me time.
Here it is...running.  I have not timed it yet.  You can see that it has a new crystal.  Another one from a box of crystals I bought off of Ebay.  Steadily improving my ROI.  But, frankly, just being able to grab something from stock is very satisfying!!
Oh...I was surprised to find that this was a snap-together case vs. screw back.
I removed the lume from the hands carefully in a baggie in case it was radium.  Baggie is sealed and in the trash.  Hands are a little rusty.  Need to research cleaning them up.
Sweet LWS!  I really like the style or font of the numbers.  I wouldn't have given the case a second look regarding authenticity but once you pointed it out...it does seem a little at odds with the style of the dial and hands.  But so what if you like it?
Are you going to re-lume the hands?  I haven't ever done it but someday....BTW, I agree on the non-shock cap jewel balance cleaning.
3 hours ago, LittleWatchShop said:
A friend loaned me a geiger counter...it is radium!!
obviously a defective Geiger counter. Didn't we decide they discontinued radium like a century ago? Yes it is one of the sad problems of if you're going to get upset about these things the radium hands are still amongst us. At least with the Geiger counter you can check your bench and everywhere you worked with it just to make sure you didn't leave anything lingering behind.
Dunno...kinda want to re blue the hands, but reading this forum...seems it is not for the faint of heart.
the bluing pard isn't exactly the problem somewhere in the group were having a discussion. The part I would be concerned about is those are not pocket watch hands and attempting to polish them in any mechanical fashion which you would have to do to remove them is going to be problematic. I'm not sure it probably turn out to be hideous mess but you can probably use a liquid rust remover to clean up the hands which will unfortunately take the bluing off. Then you may build a use some sort of a chemical bluing at least turn the hands blackish in color as opposed to broken hands. But that would probably just be me if I tried to polish them. Then if you have darkened hands that are rusty you can read Lu or just remove what you have.
    • I have only made screws down to M1 & 14BA & I had trouble getting the slot in the centre of the head so I made a jig to help me be more accurate when cutting the slot, here is my video.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
