A few projects
Thank you. Please see earlier post here about same watch
Hello Murks. Always consider if shimming the cock would do. Check if pivot shoulder rubs on setting's housing. roller table and balance rim to be checked as well. Regs
I presume you're looking for "not break the bank" as Bergeon and Horotech are standard. The set that I believe used to be A&F on the Cousins site are pretty good - Cousins Swiss Style Stainless. I've seen a lot of people recommend the Kwong Yuen set, though care to be taken with respect to the blade diameters. Everyone is going to recommend you get good quality tweezers, though I've (so far) got by with Vetus and Cousins brass ones. Good luck 😉
