Hi
I have a Victorinox Inox with (I believe) a Ronda 715 movement. I suspect I have damaged the coil when replacing the battery, I'm going the try and check with a multimeter. Can anyone advise the contact points. I have found the correct resistance, but strongly suspect mine will be infinity due to my hamfistedness. It's how we learn...
So assuming I need to replace the coil, the cheapest way seems to be buying a whole new movement from Cousins. Is it then easiest to replace the whole movement, or take the coil off the new movement and just replace that? I don't currently have hand removers so am suspecting the latter.
Thanks
OK thanks. Having thought about it, perhaps there is a good chance of me damaging the replacement coil by trying to move that across, so replacing the whole movement is best.
Any recommendations on hand remover tool? I wouldn't imagine I'd use them a lot, so don't want to break the bank, but could afford better ones if necessary.
