the arbor square out of place and mainspring thickness/height is what I would double check on this model....
For larger or longer components I have a home made demagnetiser, a old central heating pump with the rotor removed, works well. -
I agree - I use a magnetometer app on my iPad. A few years ago, I did invest in the Elma version of this demagnetiser. I have a background in electronics and when I cracked the unit open to explore it, I was very impressed - and reassured - by the careful attention given to the design and the quality of construction and quality of materials. It will out-live me, and not because of any shock hazard 🙂 I find it very reliable for demagentizing watch movements, but for tools, especially elongated tools like tweezers and screwdrivers, they need to be done in sections, a couple of centimetres at a time. I always also repeat the demagentising process several times with the object (usually a movement) oriented in several different planes - horizontally at 0 and 90 degrees and vertically. Checking on the magnetometer app, the movement is effectively degaussed and I’ve not yet had to repeat the process. Just laying the movement horizontally and giving it a single shot sometimes works, but often doesn’t, hence my process above. Using a compass, I doubt I’d ever know whether the process was effective or not. The magnetometer is much more sensitive. I still use the Lepsi app, which was available for free, but which I don’t think is available on the App Store any more.
Hello everyone, I have just started on my watch repair journey. Many mistakes …pinging springs and lost pallet forks !! My great Uncle was a clock maker with a royal warrant and his ancestor stated the first hall in London so hopefully some thing rubs off . Looking forward to following the topics on this forum
