Automatic mainspring
gary17
Hi
Guys
I have asked this before so i am sorry, but i have put a pic up the best i can gedo,hoping someone can explain it to me so i understand.
Below is a mainspring. The one i have numbered number 1 is what i call the mainspring and the number 2 is the bit added on so it catches and does not over wind.
My understanding is that number 2 goes against the wall of the barrel?
In most cases i have seen it has to, so the arbour catches the spring.Plus it tends to want to bend that way
But if i put the number 2 piece against the barrel wall of the arbour it cannot be configured to catch the spring in the middle. I have tried every differnt way you can imagine left turning, right turning, arbour up, arbour down and it don't work.
If i put it in so the arbour and spring are correct either the number 2 piece sticks out or worse still it snaps off.IMG_20201118_150526.thumb.jpg.b4ff73f3f33fe59677f1fc2dd210b777.jpgI know its not ideal winding a spring by hand but you do what you have to do with what you have. I have had this problem on nearly every spring i have tried to insert. Know problem when it comes pre wound. So can someone explain this to me and tell me how i shouild do it or what i am doing wrong.
cheers
gary
The click shows you which direction( clock or anticlcok)  ratchet wheel therefore the arbour should turn to wind.
Examine the arbour to see which end goes in the barrel and which into the cover hole, thereby direction arbour hook should sit( clock/ anticlock) is found.
Mainspring should go in so to catch the hook.
The part you numbered 2 is called spindle.
Good luck.
    • As Richard said, this is a really old school trick for joinery.  Cut i strip of paper, might need to be watch paper  around 1 " x 1/2" lay it over a staking block then press the stud screw into and through the edge of the paper upto the head of the screw. You probably wont even need to pull the paper away the head will pull itself through.
    • Thanks Jon, my mum is getting there day by day, so strong and determined, they dont make em like this anymore 🙂 Old folk are so amazing,  my mum used to love her golf, she didn't stop playing until she was 70 . Enjoy your trip and your golf.
    • Hello,  i am looking to source a winding stem (winding arbor) for a waltham 6/0 d movement. I have found some that claim to fit 6/0, 6/0s, 6/0b etc and somealso claim they will also fit the d as well. The d does have hacking which is driven by the stem seating completely. Given some of the costs of these, i was hoping someone would know of any interchangeability with a source, or know a source where a confirmed 6/0 d stem can be had. I am in the US so a US dealer is best.    thanks in advance.
    • So great to see and hear- your mum looks great! …my mil had a stroke last summer in the golf course parking lot. I’m flying out tomorrow to visit and play golf. she’s ornery because she can’t get off the tee but I hear she makes up for it on the greens since she’s been putting since a week after her stroke 🧐…
    • Very best wishes to you and your family, as a carer myself I know how difficult things can be.
