Hello I am now to forum. This watch is from 2009. I barely wore it. I recently wsnted to wear it and its not working. I wind it and nothing happens. It's never seen water or dirt or sand. any ideas?
I may be mistaken, but I think it has a quartz movement and probably requires a battery!
Welcome to the forum. :)
Edited by Geo
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
