I always wanted a carriage clock so took the plunge and bought this one for £40 at auction. The clock was a bit dirty so only cleaned with a cloth. A couple of the external screws have slight surface corrosion, a bit of dust inside the “cabinet” and the glass edges had grime build up.  There is no name on the clock, as far as I can see. I bought the clock unsure if it was working however a couple of turns with the key and tick tick it worked ! I read a number of posts on here and was a surprised to learn of the Chinese interest in carriage clocks. Is my clock genuine ? Keeps good time too.
Yes your clock is a genuine French carriage timepiece of around 1890-1910 period with a cylinder escapement and a case style know as Corniche, they where not always marked with a makers name and many retail jewellers of the time would add their own name to the dials before sale. Apart from needing a clean it looks to be in good condition the cylinder platform needs a service it is set right at the limit of its regulation so needs attention, its important that the glass appears to be in good order because it is very expensive to replace chipped or damaged ones because they have to be cut to order, the french never really successfully standardised glass size's although they made some attempt to do so.
Although this would have been regarded as a cheaper French carriage clock when produced, the quality will still be far superior to the Chinese fakes.
Edited by wls1971
Many thanks wls for your reply, much appreciated. The clock does need a clean, particularly the dust inside the cabinet. I’ve only had the clock a few days and over a twelve hour period she gained eight minutes, the “time lever” for setting the “time accuracy” being set to F. At the time I took the photograph I had set the lever to S  and over a further twelve hour period she correspondingly lost approximately six minutes. Today I have the lever set at the mid point so will be interesting to see the outcome.
When you mention the “cylinder platform needs a service” is that the mechanism at the top of the clock which I have been adjusting via the lever ?
The glass appears to be original, heavy but dirty around the edges. I suspected my carriage clock to be at the cheaper end of those produced but it does have a look of quality. Maybe that says something about it’s age. Nevertheless it’s nice to know that it is an original piece - many thanks for your time. I’ve attached of a photo of my previous favourite mechanical clock but the carriage clock is the one I look at first !
Yes that's the platform escapement, the one on your clock is a cylinder escapement, the better clocks where fitted with platform Lever escapements, which are more accurate and effected less by changes in temperature.
wis1971 has told you everything you need to know about your carriage clock. Just like to add I can't see any fine cracks on the dial which is a good thing. It needs a good clean. Cylinder escapements don't tend to keep such good time as the balance wheel is not compensated, so depending on the weather time keeping might change a bit.
Many thanks to you both. I adjusted again yesterday and is now 1 minute fast over twelve hours. I’ll leave it for a few days and see what happens. Not bad for 120ish years and probably continuous movement. I just had a look at the dial under torchlight but couldn’t spot any fine cracks.
The clock does need a clean externally but internally too. I was thinking of removing the case only and using a paintbrush to remove the dust. There is a single screw on the base which seems to be the first hurdle to access. I’m not too sure if I should polish externally. From previous posts I read that such clocks had a gilt finish. If so most of mine has gone so I may be end up polishing brass that was never meant to be seen ? Thereagain at the cheaper end of the spectrum the finish was maybe not gilt ?
Much appreciated, R
First I would put an elastic band around the case, this will hold it together. Turn the clock upside down and some times there is a plate that has a screw in the middle (many plates go missing) un-screw that and you should have four screws in each of the corners, you need to un screw those (make a note to replace them in the same holes when putting the case back together) the movement should just lift out. The band will hold the case. make sure when putting back you get the pin on the door to go in its hole.
If you want to polish the case and movement just ask and I can help you.
Thanks. There is a plate in the bottom with one screw in the centre. I take your point on the door pin, I’ve had a good look ! (The door closes well being a good fit - again surprising with her age).
Looking at the fittings I think it is some time since the clock has been opened. I’ll let you know how I get on.
Thanjs, R
I just looked at the above photo in detail. There appears to be a few letters with a number below. I didn’t notice that before. I’ve attached a better photograph. Could be
LP 4198.
Removed casing and dust freed clock as per instructions. Used the elastic band suggestion which no doubt avoided a problem or two. Noticed a repair to a couple of teeth in the large cog on the “spring drum”. Nearly forgot the door when reassembling. Most awkward part is the alignment of the single screw on the bottom cover plate. Again many thanks,
R
Thanks for all your help. I must admit the clock now looks a lot cleaner and should be good for a few years I hope. The photographs don’t do it justice.There are always a few carriage clocks at the local auction and from my limited knowledge they don’t have that “Made in China” feel to them.  I’ve also had a look at other carriage clock movements and a number of them have many more working parts than mine ! I’ll keep an eye open for something a little more upmarket,
Thanks Again,
R
Just remember this about carriage clocks. If the movement has had a new platform fitted leave it alone, the value will have decreased a lot. Good dials are a must, any cracks no matter how small will also effect the value. The glass panels can be very expensive to replace.
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
