Need a balance staff for pocket watch
I have got some with J>140 but  A~620,  One would think to cut out a pivot on it at 580 on lathe. The measurements you gave are inexact too.
To do without lathe,  we both should do better homework.
I have set aside a number of possible candidates.
I’m now thinking of getting a lathe, I managed to get the A measurement by balancing staffs in place until I found the correct one. The other measurements I got from the existing staff. Thank you so much for looking through your collection you’ve definitely gone above and beyond. The movement is Swiss and doesn’t seem to conform to a standard size, I could potentially ask a professional to trim an existing staff to size, I would love to buy a lathe and adjust one myself but money is definitely tight during lock down I have a feeling that this project will be ongoing for some time. I suppose being patient is a good virtue for a amateur watchmaker :)
On 6/10/2020 at 2:17 PM, JohnR725 said:
I don't suppose you have a picture of the dial side showing the setting parts?
Then the website below you can enter in dimensions see if anything matches or if anything's really close because then you can just modify it. Like very first one on the list Buren (BAA) Looked relatively close. Another place to look is the bestfit book Which also has a listing of balance staffs by size.
https://www.balancestaffs.com/product.php?dim_A=580
Neither I nor Daniel have lathe to do the modification. he can modify J & G with a broach and I haven't come across anything suitable yet, begining to look into other options.
Edited by Nucejoe
balance staff let you enter A & B only.
1 hour ago, Daniel123 said:
Not sure if this helps but I've been doing research and the movement is a IWC Swiss made and imported to USA not sure how it then ended up in Wales but it must have had an interesting history. :)
Weren't IWC movements made in-house? Did IWC source staffs from Ronda?  I think I should have found an exact matching one by now.
ok it looks like IWC made the case and Droz & Perret made the movement, a few people are suggesting that Droz & Perret was part of Longines? the movement has St Imier on it. Ive been looking on balancestaffs.com and there are some very close matches on the Longines list.
On 6/11/2020 at 9:26 PM, Daniel123 said:
Yeah it’s a bit frustrating you can only search by A & B then you hit return. The list should show up below then it’s a case of clicking on each of them to find the best match.
Thank you Daniel, I tried that, worked.
    • Hi All, I'm Geoff and I've been working on/with watches and clocks since I was thirteen. My dad was a watchmaker and while he did not want me in the field as a profession, I've always maintained a pretty good working knowledge. In the '70's I kinda got pulled back into things because Quartz revolution began and he only had limited electronic knowledge. So we combined skills. He the watchmaker and me the electronics tech. Being here in NY helped because we got to know the folks from Bulova, Seiko, Citizen, and WOSIC. H.B. Freid was my Dad's teacher and I was fortunate enough to get to know him too. I still maintain a bench here at home and occasionally work on watches for friends although the hands aren't what they used to be. Not going to be working on any FHF59 or AS1012's any time soon. Oddly enough though my years working with the field taught me how to work on almost anything else mechanical and mostly electronic. Since I was the one in the family who maintained Dad's cleaning and timing machines. those experiences carried over quite nicely into the worlds of recording and audio as well as others. I look forward to the discussions and maybe still learning a trick or two. Cheers to all and nice to be here.
    • The best and almost only way to achieve the magical £ 4.04 individual watch cost is via the loophole ploy of job lot buys Ross. Dividing down the outlay by the number of watches purchased. I've managed it many times in the past, this then gives you the extra edge of choosing any watch from that lot. Maybe we should have an all time winner, whos prepared to troll  through the last four years of posts and pick some worthy contenders. Unfortunately i have a poorly shoulder so i cant raise my right hand and my left shoulder is out in sympathy for my right shoulder. Put your right hand up if you think i talk a load of bull 💩     🖐 Tom's comment is purely restricted to  the Bergeon culture of " lets rip off everyone on the planet " Voted , i thought to keep it in pounds as originally designed and out of respect for Andy . Personally i would have kept the £4.04 as I'm very traditionalist and dont like change but i know how hard you overseas guys are finding it and i believe in fair play. I expect to be posting the occasional Omega or Longines but then you brought this on yourself so dont get jealous Scott 😆
    • Ah but, will you count DIY versions.
    • £10.00 is not a huge amount for a watch these days with the increased asking prices. Let’s count ourselves lucky we don’t have this for tools, it would be £404.00 🤪   Tom
