Afternoon all,
I have been rummaging through my collection of bits I have yet to use that came from various sources. As I'm embarking on learning to turn, with the intention of producing some balance staffs (great videos by the way @jdrichard, thank you for taking the time to make them) I am looking at what comes after, ie burnishing.
I have most of a jacot tool, it's missing the 'drum' (not sure what the part is called). Is it likely I will find one somewhere or is it a lost cause?
Or is there an attachment for my lathe (Pultra 10) that I can use instead of a jacot?
I also have what I think is an old burnishing tool to use with a jacot, am I right in thinking this is what it is? What's the best way to clean one of these up?
IMG_5680.thumb.JPEG.3a8ba115f3402ddb6a6389dbb6ae51ff.JPEGIMG_5682.thumb.JPEG.a8662ebd0eb3fe12a66e95b79a65d0f5.JPEGIMG_5683.thumb.JPEG.88020258d6b1acf5a01e9921f45e3eb4.JPEG
Thanks in advance. I'll get there in the end, if it damned well kills me!
Hello,
New lanterns can occasionally be found but it is rare. More often these tools are sold with damage to the same parts. It is possible to make or repair the parts which are damaged with a combination of tools which will generally differ by whether they include a 90 degree double angle milling cutter or a tiny drill - for grooves or holes. Off the top of my head, the depth of grooves with a 90 degree cutter is a depth of 0.65 times the desired pivot diameter.
I'm assuming the issue is with the disk with tiny holes in it.. it can be possible to anneal the damaged end and to turn most of it away, leaving a boss concentric with the outer diameter which fits through the tool. The end of the boss can be tapped for a retaining screw for the new part, or the new part can be glued/ bonded on the end - both parts will want to be a nice close fit so that the new part remains concentric if drilled before being mounted to the old arbor / part of the tool. The new disk can be steel or brass (they don't see a massive amount of wear but may have abrasives embed in them, and will wear out quicker than steel). In order to drill one you'll need a way of indexing so that you can use the tools existing divisions (the star shaped part and guide). It is possible that a new disk may be able to be drilled or center drilled in place on the tool with some creativity.
I've also got a jocot tool with a damaged disk, shall repair it eventually but just use another for now.
Your other tool may still be or have been a combined pivot file and burnisher. It depends how it's been used in the past as to what it will be like now. One or both ends may be dressed as a burnisher - depending what sort of tool they presently appear to be, if one end is still a pivot file then you may wish to keep it as one.. a pivot file is useful so I'd keep it as one if it's in even partially worn condition.
Basically to dress a burnisher you could use traditional techniques such as oilstone dust on a lap with a bit of oil, or nowadays you could use a modern abrasive of a similar grade. The process creates tiny grooves in the tool from the abrasive which do a combination of really fine cutting and burnishing the pivots you apply the tool to. The burnisher would be moved across the abrasive and rolled over part way through the stroke, starting with a large face then rolled onto the next smaller face. You will see that there should be 2 sharp edges and 2 rounded edges, that will indicate which edges are rolled over and which shouldn't. It will probably take a bit of time if there are any imperfections or surface rust, etc to remove - you may choose to work on a side at a time to flatten and remove imperfections before dressing it.
Edited by JGrainger
addition
    • I've gone the threadlocker route having tried the material insert approach without success. The watch runs but I'm chary about winding it more than a turn or so in case the 'repair' gives way; still, there's an element of satisfaction in getting it going at all as it's a single bridge/plate design which I could only assemble dial side up & then flip over in order to be able to insert the 3 securing screws. The reassembly took a number of attempts over many hours but at least I got considerable manipulation practice & the experience will come in useful in future. I'm now faced with my ignorance about how to manually set the the time as this key-wound Waltham pocket watch doesn't have the usual pull-out stem facility. All I can think of doing is to adjust the regulator arm until it catches up with the current time & then revert to the central position.....
    • So the crown should be a 0.9mm thread as you've ordered. How do you know the thread size is wrong if you've not removed the broken stem yet?
    • You'll need to be extra careful with the Citizen as Information along with Parts and Donors are pretty much none existing. You'll probably end up having to use a stem extender, that's hoping there's enough stem left in the movement.
    • Thank you! That's immensely helpful. I appreciate the trouble you've taken. The initial hiccup aside, I do hope to treat this watch with great care and respect. I've certainly learned one thing not to do, and also just the general need to start out very slowly and very carefully.
    • 166.128 is the case reference number and the Omega logo is on the crown. This is the watch.
