Hello Forum,
I started this project of servicing a Seiko 66-9990 (my first "real" project).
I would like to replace the crystal and started looking for information but am struggling to find any specifically for this model (maybe too old ?)
My questions:
- Is there a way to find the correct Seiko reference part number for the crystal for this model ?
- Is there a way to get a "tech sheet" with all Seiko part numbers for this movement (66 A) in case I need to order any replacement parts ?
Many thanks in advance for any help and/or advice
Best
Joao
2 hours ago, FLwatchguy73 said:
this has the part number you're looking for.
Thank you watchguy!
One question though: I came across some ebay listings with that part number for the specific case but how to be sure that the ref is the right one ? You can't allways trust the listings/sellers ... ;)
Thanks again for your help!
Further investigation revealed that the Crystal I initially suggested may not be correct. Boley in Germany has all cases and crystals listed for nearly every model and brand of watch. Please see the screenshot and link below. I would trust the accuracy of Boley's information over anyone on eBay.
https://boley.de/en/case-parts/seiko/20719.6600-9990?q=9990&p=0&s=50&l=18
1761520118_Screenshot_20200423-092703_SamsungInternet.thumb.jpg.b6885c3e76467c948875c1b9293f78b1.jpg
That said, Jules Borel in the states lists the original part number I posted. Jules Borel is also very reputable. Looks as if the original part number is easier to come by though.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=W]bcWFdcTH
Edited by FLwatchguy73
1 hour ago, FLwatchguy73 said:
Further investigation revealed that the Crystal I initially suggested may not be correct...
I think that both references (318N02AN00 and 318N01AN) refers to the same type of crystal, a 31,8 mm non water-resistant with no accesory (like tension ring etc) acrylic crystal. The 01/02 in the middle of the code is just a serial number for production classification, and the 00 at the end, not specified in the first code, means a transparent crystal.
Cousins have this crystal out of stock, but they say it's expected by 2 June
https://www.cousinsuk.com/search?searchTerm=318N02AN00
Edited by aac58
