Hairspring Vibrating Tool.
Many thanks all. I'll have a go at straightening the hairspring, for my practise really. I expect I'll be sourcing a donor movement anyway as I need an escapement and pallet fork anyway. Will update.
Dr bonefixer are you serious ? A true watch repairer never throws any scraps in bin, there are many good parts in OP's watch. This has saved me plenty of $ . Regs
The only way I've ever know to do these is by hand.
Repaired an old Tissot stylist a while ago, but the only thing I was never happy about was the crystal, polished it however there were some scratches that were too deep to remove. Recently found a matching acrylic crystal from cousins that should fit the watch. The problem is i'm not actually sure how to install the crystal into the case. It doesn't appear to be glued in, and there is a small lip in the crystal and a groove in the case for it to fit into. I tried using a crystal lift and also a crystal press (with round dies) on the old crystal as i don't mind damaging it. Any advice would be appreciated, hoping i'm missing something simple. Thanks!
As Andy states , the model number points to a battery powered quartz watch.
