Poljot 2614.2h
Wfvk
Help how do I get mij balance attached to the cock? Or is that the wrong term?
The old balance was broken etc.
Now I have a couple new replacement ones but I cannot get it reattached. Just to much movement etc. How do you guys do this?_20200220_233225.thumb.JPG.e8d83d43d42a8d7dc5a1f4c1038f731d.JPG
Edited by Wfvk
Grammar
Hi the terminology is ok.  To connect the two parts first open the regulator (boot) by turning through 90 deg, this will expose the pin.next lay the balance in the jewel and manipulate the balance spring stud into the hole in the arm and just screw the screw tight enough to hold the stud. And close the regulator boot back to its correct position .  Now re fit the complete assembly into the watch taking care to get the pivots in correctly, at this point do not screw down the cock but recheck the balance fitting. end shake etc and its free rotational movement. While the balance is rotating slowly screw down the cock maintaining the free rotation. Once done ant the balance is fitted and screwed down check the flatness and concentricity of the spring if both are in good order finaly tighten the stud holding the spring.   Hope this helps       Cheers
    • Nice interesting diver Razz, i have a sheffield dress watch, different movement altogether. Could be a wrong motion works part, how does the setting feel before fitting the cannon pinion, clutch and intermediate wheel meshing ok ?  The less traditional setting design could be suspect, the second wheel has a slip clutch assembly, that most likely needs looking at. LA is 42 ° Razz Tbh i  much prefer to call the complete unit the lever, then use the seperate names for all of its components. Such as guard pin, fork, fork horns, fork slot, lever arm, pallets , pallet arms, pallet slot, pallet stones. I suppose pallet fork is the combination of the two opposite ends that make up the lever, its also called the anchor which is descriptive of its appearance.  Its a pretty basic 1930s  swiss lever movement H and yes Nev was meaning the pallet fork.
    • The pallet fork should really be called a lever, English lever, Swiss lever etc but most people including myself call it a pallet fork.
    • Seiko have case numbers, I  can't see it on your photos.  If you can find that we can look for a genuine crown.  If not, you need to measure the diameter of the stem, the distance between the lugs and the depth of the lugs.  The case number will be something like this.
    • I'm not sure what kind of movement this is, but I'm curious to know if you're using the word "lever" as a synonym for "pallet fork"?
    • Actually kind of rough, maybe munute wheel pinion problems? Is the 2.73mm canion oinion which seems rarer and not availble on Cousins UK. The seconds hand works and suprising nice amplitude but don't know the lift angle and BE this one says 17 j but is a pin pallet as well. Cap jewels on the escape and drive train pivots. Interestingly in has both water proof and shock resistant on the caseback and dial. Puts this around 1969 or '70? The double bezel that works independently is cool has the pi symbol on each. Wonder if it can be used like a slide rule ir something...
