Hi guy’s! I’m looking for help on buying & fitting a suspension spring on a french mantle clock with a mercury pendulum!
It’s a brocot movement! I’m looking for diagrams on fitting the said suspension! Cheers!
Here you are. You have three that will fit from my experience 27x5mm should be right, you will need to file it out a bit for it to fit, make sure it is free moving and so it doesn’t snag. Number  0299 000115
http://www.m-p.co.uk/muk/parts/suspensions.htm
Many thanks for the reply mate! You mentioned filing something? What will need to be filed mate!
