Homemade watch hand setters
Dpastl
Hey All,
I thought I'd share the plans for making watch hand setters.  I wasn't able to get any cheaply or easily so I decided to make my own.
A note of caution, turning small diameter PVC is a pain.  I was able to after much trial and error, but the accuracy was pretty bad.  To be fair I was using an enormous 13x48" engine lathe with a 3jaw chuck and HSS tools ground for steel so your results may vary.
Design is based on pictures of other watch setters I found on the internet. I chose 0.5mm, 1mm, 1.5mm and blunt tips.
Cheers,
Watch Hand Setter Drawing.pdf
  • Thanks 2
On 4/30/2019 at 6:49 AM, dcronin said:
Dpastl, if you're using that on Rolexes, it is probably good enough for anything I'll get my hands on (no pun intended)!
That is the butt end of a center punch, I'm guessing.
No rolexes haha.  I only have older AS movements for the most part. They work super well, especially in comparison to pegwood with a hole.  That was not great.
Center punch?  They're all custom turned parts as per the plans.
    • Hmmm you know when i said some damp might have caused the bubble originally hmmm 🤨
    • Are you all jerking my chain, I'm a yorkshireman £4.04 is too much 😆
    • [Myota2034] Custom simple quartz watch — PricewaterhouseCoopers On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting. It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses. Clever for a simple watch!⌚️
    • I think someone else has though. Some where here using a modified perspex sheet. I may be wrong i may be right , i think it involved fitting the arbor to a pin vice. I dont have experience of the bergeon winders, are the handles not interchangeable ?
    • Never tried dial dots, i always considered them as a bit of a bodge.  You are adding something that was never intended to be there. I wonder how the adhesive reacts to any part of the movement, hot summer heat and i think things might turn sticky. Most adhesive backed stuff has a tendency to soften and slide around so it may spread, i have used a lot of so called sticks all adhesives in my industry that are just not up to the job. I suppose they get you out of a problem quickly, but how permanently might that be ? I would just explain to the owner that it may or may not work. WWs other ideas are a much more permanent solution but both have their risks . I've tried milling and dial feet replacements, hmm it was ok, ive heard of folk dimpling the face , so that needs care . And i have soldered a few times , all with good results but i am very careful and I practiced it a lot.
