opening a caseback issue
So how did the dimensions stated as 30.1 x 25.3 compare with what you received and how do those figures compare with the original.
Sorry, had to leave for work, will post photo when I finish.
I don't know that yet 🙂 The part that is visible is NOT threaded and much thicker, that's why I'm confused... I'm gonna try unscrewing it and will report back. Thanks for the help so far!
When you say exactly, how exactly ? 0.1mm can make a difference. I've trimmed fancy crystals to fit, the final fit is down to very small adjustments. The four corners maybe make the crystal more rigid than a round one.
