Hi All
I'm a beginner and this my first attempt to install a mainspring on an automatic.  The movement is AS1700
I understand that I'm to place a small amount of braking grease to the inside of the barrel.  I've purchased moebius 8217.  Two questions come to mind 1) how much of this should be applied and 2) when I push the new spring in won't it simply push the wall grease to the bottom??
Here are pics of the old and new springs.
Many thanks for any help!
Charlie
I'm a beginner too. But for what it's worth my method is this. I put on gloves and apply a thin coat of 8200 to the spring itself. Gently running it through my thumb and forefinger. I put a few dots of 8200 on the barrel wall and, as in the illustration below from Practical Watch Adjusting, 3 dots on the side of the coiled up spring. I use D5 on the arbour at the points shown in the illustration. Just a little dot is sufficient. It works pretty well for me.
Hi Charlie,
I did an AS 1700 myself not long ago, and I also bought a new spring, which is much easier than reusing the old one. You'll find that that holder it's supplied in is slightly smaller in diameter than the inside of the barrel. Just lay it on top (check the direction!) and push the spring carefully down into the barrel. As the spring escapes from the holder it expands into the barrel.The grease you put on the inside wall beforehand will be squeezed outwards rather than downwards.
I wasn't sure how to describe the right amount of grease, so I looked for a video on you tube and found this one - Classic Watchmaking: Barrel Wall Lubrication. He greases the barrel wall right at the end. The answer it seems is a HUGE amount! Certainly much, much more than I put in. Maybe some of our more experienced members can offer their opinions.
Thank you both.
I didn't plan to unwind it from it's package; just push it in.   I've read that some springs come lubricated with teflon.  As you can see the package doesn't state it.   Would you still recommend I use the 8200 (which I do have).
Yes!  It does seem like a good amount.
18 minutes ago, margolisd said:
Do you have a winding tool?
Yes but its for springs that wind in the other direction.
if the spring feels dry to the touch then I would definitely add grease. From what I can gather, it's hard to over-lubricate mainsprings. You just don't want it leaking out of the barrel and all over the rest of the movement. Not enough lubricant on the other hand is bad. If you've got the 8200 then use it. I'd put a smear on the inside face of the barrel and the same on the lid, then two or three spots on the coils once the spring is in, like margolisd shows in his post above.
I think the dilemma is whether to apply the 8200 along the length of the MS through the thumb and forefinger as I suggested. I normally do this but I don't know how much difference it makes. If he does this it means he'd need a mainspring winder to get it into the barrel which he doesn't have. If he skips doing this he can pop it right into the barrel from the holder it's packaged in.
    • If the weight was worn how does the post look as normally you'd have to replace both. There should be no real resistance at the end and just be able to keep on winding. Did you insert both springs the same and is the idler gear OK.
    • Assembled and running well, I'm asking after the fact. I'm waiting on a new oscillating weight as this one was worn (they have a reputation for it apparently, no bearings). So I've been winding it by hand, but meeting quite a bit of resistance at the end, more than I think an automatic weight will overcome. It's not quite as sudden as a manual mechanism, but there's very little in it, certainly enough that I would be concerned about breaking something if I continued.
    • Remove the cannon pinion from the dial side first. The "clip" you describe is sort of a metal tab some American companies designed their cannon pinions with in order to make it easier to tighten friction. If that is the problem, the solution is as simple as gently squeezing the tab with tweezers to bend it ever so slightly inward, while supporting the inside of the cannon pinion if possible (it may be harder to support inside since it does not have an open tip as a hollow tube) The cannon pinion should just pull straight off of the arbor on the dial side if you pull it straight up with tweezers. There's no jewel in danger of breaking and the arbor is thick so there isn't much risk of breaking the arbor. But when you are describing that the center wheel's pinion is not turning the arbor, is the pinion firmly attached to the center wheel? If you remove the center wheel and hold onto the rim of the wheel, does the pinion turn independently of the rest of the wheel? It should not.  I'm not sure if this was the case on older Waltham, but the pinion may be threaded onto the center wheel arbor and they are often loose. This was a safety mechanism for a broken mainspring and may just need to be tightened back down. I can't remember for sure, but these might be a reverse (left) thread instead of normal right. And does the entire arbor turn independently of the wheel? Also should not.
    • You may get some extra friction on the barrel lid so may not slip as easy but I wouldn't think it's a problem. My suggestion would be to finish the assembly and see how it runs.
    • I have a Waltham key-wound pocket watch, small seconds: 20640806 on base plate & 640 80 6 on top plate. The pinion shown in the photo of the rear of the top plate - driven by the barrel - is loose & doesn't turn the main (first ?) wheel on the same arbour. The other photo shows the arbour on the dial side which appears to have a clip of some sort around it. I'd be grateful for advice as to how to proceed to rectify this problem.
