Hi, if anyone knows what crystal will fit this Seiko and where to get one please share, thank you!! Also gaskets...
If I am just to measure diameter, what type of crystal I should look for?
Thanks.
 Well, when I wanted one, cousins would be my first stop, all you need is the numbers.
Then there's  ebay , again just put in the case number, also it will give you a good idea of what you've got.
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
