So I was removing a balance staff with broken pivots, btw hi I’m new here but not new... I read this forum all the time and received marks certifications in servicing and fault finding.. the watch I’m working on is an old omega 30T2. So, the roller removal went perfectly, I flipped the balance wheel over and lined it all up in the correct hole and all it did was break the staff up to the wheel and flatten where the sink is. I can push the stake no further. So, I’m guessing it’s jeweling tool time? If so should I use the pointy rivots, or a conical shaped thingy to get the rest out?
Any advice would be most appreciated! Huge Thanks to you all for just reading so many different questions and answers on here has helped me so much in the past that I haven’t had to post much!!
I know this is a silly question but are you sure you are using the tool correctly?
if you look at Mark's video he makes it look really really simple and that's why he's using the tool. So if it didn't go that smoothly why not?
I've attached an image of how the staff is supposed to be in the tool when you're attempting to drive it out. So the hole needs to be sufficiently big to allow the staff to clear. You should be resting on the shoulder the pivot. The whole thing does have to be in alignment. Then light taps are required if you really have to start hammering on it then you have a problem and this isn't the way to take the staff out. This is where it be helpful to have a lathe you can either weaken the rivets or cut the hub off.
For clarification it would be nice to have a picture of what's left?  if you couldn't get the staff out with the tool and it did break like you said attempting to drive out the rest of it probably isn't going to be in your best interest. If you're not careful you're going to end up bending the arms distorting the hole or something much worse like basically destroying the balance wheel.
https://www.youtube.com/watch?v=vIQvAm4GC5U
https://www.youtube.com/watch?v=nlA49SmNMZM
Yes I watched his videos like a hawk and repeated the steps he took bit by bit. I didn’t have the hammer he had though so I used a rubber mallet.. that could be where the mistake was made. I have found though, through life in general and in every subject of practice, that the professional always makes it look easy. One shouldn’t expect to get it right every try when just starting. Anyhow, I bought that hammer and I never did get to remove that balance staff from that wheel completely, but I had another scraper and I was able to remove the staff correctly AND I reaffixed a staff to a balance with a (new to me) staking set that puts my old K&D to shame! I was in the basement where my work area is screaming YES YES YES and doing the body motions to follow.. well, my husband snuck down, took video with his cell and sent it to my closest friends... high five!
I did that yes yes yes dance for a few minutes.. I was so excited.. and the yes dance was done with a loupe in my eye!
Well I think that it’s only fair we see the video of your victory dance!
[emoji6]
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
