Showing results for tags 'ronda 515'.
So this is my very first project I have decided to tackle and my first posting. If I do anything incorrectly, please let me know and I shall correct it asap. So i decided to fix some old watches i had sitting in a box. I believe this watch is the very first watch I purchased myself, at the Victorinox store in the Garden state mall NJ. If I can fix it , i will donate it to my church to help disadvantaged youth dress for interviews and find jobs. The movement is a Ronda 515 1 jewel. I need a crown and tube for this case. The stem seems as it is intact. The crown is required to put the stem in second position , allowing me to remove the stem. I searched All the mechanical drawing, but i cant find the crown type. Is there a special tool required to remove the tube and is it complicated? the crystal is cracked and heavily scratched. so I will need to replace it How do I determine how to remove the crystal and what type of crystal is it, so I can try to find a replacement Definitely will need a cleaning, so once i figure out best oil solution I will do that. I am curious why the watch doesn't say Victorinox on it? Thanks in advance for any advice or suggestions.
Hello. Just wondering if you can help me. I got two new Ronda 515 movements and they both do not work. I cased them both and they both do not work. I am going to buy more of these movements, but I refuse to believe that every movement I got is bad. Is there a way to jump start these movements? Thank you for your time.
Hello all, I have a watch I would like to fix my self. It's made by TAWATEC, who is no longer in business. It's very similar to a Luminox and used TGS for lume. I will provide information to the best of my ability. Here is a link to some information about it. Here are a few pictures of the watch. I have had the watch since May of 2011. I had the battery replaced in Feb 2015 by a local shop. Less than a year later, I noticed that after taking a shower there was condensation under the crystal. I pulled the crown and left it sit to air out. After about a week I pushed the crown back in and the watch no longer worked. I wondered what caused it to leak. I then remembered I had to change the date on the watch a few days before condensation had got inside the watch. When I was trying to set the date I noticed that it was difficult to pull the crown out and it was more difficult to turn than usual. My guess was that the gasket/O-ring that is on the stem/crown was messed up and had ripped and water had entered that way. I left the watch sit for a year and used another watch as my daily driver. I'm hoping to get this one up and running again. So I recently decided to see if I could fix the watch myself. Here is what I have done and have figured out so far... I was able to remove the case back by removing the 4 Phillips screws. Visually inspecting the O-ring that seals the case back, everything looks good. The movement is a Ronda 515. The plastic ring that holds the movement inside the case says Ronda 515 # 6. I was able to remove the crown and stem. Looking towards the inside of the crown there was remnants of the O-ring. After clearing the remnants and putting the crown back in, the crown moves freely. I also found remnants if rubber on the front of the dial. After inspecting the battery, it looks to have leaked its electrolyte What I would like to do first is replace the O-Ring that's on the crown and put a new battery in it. If I then determine that the movement is damaged, I can replace it later. What do I need to do to figure out what size of O-ring I need for the crown? I can take pictures of the crown/stem if needed. I also have analog calipers to use that are in inches. Thanks for your time!
