Showing results for tags 'replica rolex'.
Found 2 results
  1. I got a replica rolex 3235 movement, a complete clone as far as I can see with me. Used for a submariner homage project I embarked on. 2 Months in, when I took the hands out for a polish and cleaned the dial, after I had replaced the hands and recased, the minute hand and hour hand started to intermittently stop and lag behind. The second hand was perfectly running at a nice -5 seconds a day. I took it apart for an inspection, nothing looked broken in the gear train, and the timegrapher numbers were still excellent, but realised that the hands would shift extremely easily when pushed. I never took notice whether that was normal or not, but based on my suspicion and a little extra research I concluded that the canon pinion was loose on the center wheel arbor, So here is the issue, there are no known 'good' watchmakers in Singapore that will work on this replica movement, and its quite difficult to find parts, unless I swap it out with a genuine canon pinion. I've heard of a cheap way to tighten it using a shaved down blunt nail clipper, but would like to know. How 'tight' is tight, when I push the hands while the crown is in the hand-setting position, am I able to push it? will it require alot of force? or just not move at all without breaking it? Is the friction-fit canon pinion just supposed to be tight enough that when the setting gears are tucked away, the centre wheel can continue to power the watch? and while the second hand is hacked, there enough slip that the hand can be set by the crown? Are there any other options to repair it? Im still a student so a cheap option of repair would be nice. Thank you all for reading.
  2. I own a fake Rolex submariner and the piece that connects the band to the watch is missing. I want to get this piece replaced but I fear that getting a replacement piece from a Rolex store would be way to pricey, and getting a cheap knockoff piece online would be, well too cheap. Is there any place to purchase replacement parts for an affordable price?
