Seiko sarb033 help
I have a sarb033 (beautiful watch) but my problem is that i need a new Balance wheel and i can't seem to find one, could anyone tell me if a balance wheel from a 7s26c movement would be the same as the 6r15c movement in the sarb033, thanks
Even if  the OP is not in the UK, Cousins UK ships worldwide and cost is very low for orders under 25 GPB.
A 7S26C balance may work but the specific one has a different P/N: 310.046
Edited by jdm
Yes thanks for the info i have been into the site and have seen the specific part code, the thing is it's only the balance wheel and i was looking for a balance wheel + cock in one like this only with c type balance IMG_0049.JPG.a666ea9122d0fabb000da6a8e87f41a6.JPG
If your issue is not being able to replace the hairspring end stud to the balance cock, then be aware that the two parts are not sold together, so either learn how to do that as explained in the attached service guide, or bring it to a watchmaker.
If you are really have a faulty balance cock (please tell why you think so), I have plenty of these and can send for postage, just PM.
7S26C.pdf
Ya the two parts( balance wheel + cock) sold separately are no good to me cause i wouldn't be able to replace myself, you'd really need to be sure of yourself doing it that way, but if it was together like out of another movement I'd be able to do that, that's why I'm looking at buying a movement and taking out the cock and balance as one, it's easier, I'm currently looking at a new 7s26c movement on eBay, it seems the 7s26c and 6r15c have nearly all the same parts including the c type balance
As mentioned above the specific 6R15 balance complete has a different P/N from the 7S26, even if clearly the overall architecture is the same.
If you are  beginner don't mess things further mixing parts. You do not have the right tools (including a timegrapher) and skills to do the work properly. Bring or send your watch to an independent watchmaker or Seiko service center. Otherwise sell the watch as it is disclosing the problem and buy another, these are very easy to sell or buy.
    • Hmmm you know when i said some damp might have caused the bubble originally hmmm 🤨
    • Are you all jerking my chain, I'm a yorkshireman £4.04 is too much 😆
    • [Myota2034] Custom simple quartz watch — PricewaterhouseCoopers On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting. It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses. Clever for a simple watch!⌚️
    • I think someone else has though. Some where here using a modified perspex sheet. I may be wrong i may be right , i think it involved fitting the arbor to a pin vice. I dont have experience of the bergeon winders, are the handles not interchangeable ?
    • Never tried dial dots, i always considered them as a bit of a bodge.  You are adding something that was never intended to be there. I wonder how the adhesive reacts to any part of the movement, hot summer heat and i think things might turn sticky. Most adhesive backed stuff has a tendency to soften and slide around so it may spread, i have used a lot of so called sticks all adhesives in my industry that are just not up to the job. I suppose they get you out of a problem quickly, but how permanently might that be ? I would just explain to the owner that it may or may not work. WWs other ideas are a much more permanent solution but both have their risks . I've tried milling and dial feet replacements, hmm it was ok, ive heard of folk dimpling the face , so that needs care . And i have soldered a few times , all with good results but i am very careful and I practiced it a lot.
