Stowa A.s. 1880
Don
I had in mind, as my second project, a Lucerne Super Flat I sniped off the Bay. Upon stripping it down, I found it was a pin lever movement. Although it would be good practice to service it, I'm on the fence if I want to spend the time, cleaning solution and lubricants on it. In the meantime, I decided to start another project. I bought this Stowa watch four years ago with the idea of getting it serviced. I found that to be cost prohibitive, so it has sat in a box until now.
It wasn't running when I got it and when I opened it up I saw why that might be. There is green and black gunk all over the place. My working theory is that the o-ring disintegrated.
Once some of the gunk came out, it started running! Now I'm a little stuck. This movement is a little different than the Caravelle I worked on first. The second(?) wheel has a friction pinion on the dial side of the movement and I need some advice as to how to remove it. I have a Presto type Bergeon canon pin remover, but it can't get down far enough to work.  I'm also curious curious as to the function of the pinion in question. In addition, there is a spring on the dial side that I'm having trouble removing and wondering if I even need to remove it. The following photo shows the friction pinion on the right and the spring on the left. Any advice would be greatly appreciated.
Don
I just watched Mark's video on the AS 1900 and he did not remove the spring. Also, I gave another try pulling the friction pinion gently with my tweezers. This time it came off and flew across the desk. I feared that it had gone to join so many other parts in that limbo where watch parts and the missing sock from the dryer reside, but I was fortunate enough to find it. So, consider my current problems solved.
I always use my tweezers for the pinions, I use the thicker part behind the tips. It ensures that the part doesn't fly away and preserves the tips! Of course a pinion tool is better and ensures a straight extraction. In any event, good job Don...and you just gave away another hiding place I should search for lost parts! Never thought they would team up with socks! :)
Finally got back to this project today. I removed the mainspring from the barrel and sorted all the parts in the my new cleaning baskets. If I have time tonight I'll run them through the ultrasonic. The mainspring looks good. I was going to replace it, but I think I'll give it a try first.
    • Nice interesting diver Razz, i have a sheffield dress watch, different movement altogether. Could be a wrong motion works part, how does the setting feel before fitting the cannon pinion, clutch and intermediate wheel meshing ok ?  The less traditional setting design could be suspect, the second wheel has a slip clutch assembly, that most likely needs looking at. LA is 42 ° Razz Tbh i  much prefer to call the complete unit the lever, then use the seperate names for all of its components. Such as guard pin, fork, fork horns, fork slot, lever arm, pallets , pallet arms, pallet slot, pallet stones. I suppose pallet fork is the combination of the two opposite ends that make up the lever, its also called the anchor which is descriptive of its appearance.  Its a pretty basic 1930s  swiss lever movement H and yes Nev was meaning the pallet fork.
    • The pallet fork should really be called a lever, English lever, Swiss lever etc but most people including myself call it a pallet fork.
    • Seiko have case numbers, I  can't see it on your photos.  If you can find that we can look for a genuine crown.  If not, you need to measure the diameter of the stem, the distance between the lugs and the depth of the lugs.  The case number will be something like this.
    • I'm not sure what kind of movement this is, but I'm curious to know if you're using the word "lever" as a synonym for "pallet fork"?
    • Actually kind of rough, maybe munute wheel pinion problems? Is the 2.73mm canion oinion which seems rarer and not availble on Cousins UK. The seconds hand works and suprising nice amplitude but don't know the lift angle and BE this one says 17 j but is a pin pallet as well. Cap jewels on the escape and drive train pivots. Interestingly in has both water proof and shock resistant on the caseback and dial. Puts this around 1969 or '70? The double bezel that works independently is cool has the pi symbol on each. Wonder if it can be used like a slide rule ir something...
