Baselworld 2018, Where can I get cut price tickets?
Little chance for a direct transfer to work, even if both movements are of exact same caliber. If lucky you might have a close match, in which case adjusting is done by adding or reducing balance weight. Otherwise its down to assortment of overcoils and hope to find a close match. Welcome here and good luck.
Welcome to the forum. Are they the same movement?
By rottobotics · Posted
Thank you both. Out of curiosity, what are the conditions for each post to not need approval by a moderator? I've been on the forum about 5 months, started 2-3 topics, and have 14 posts. -
I appreciate the suggestions. The o ring was hardened and Cousins would have cost $13 shipped, so I ended up sanding and filing a 2mm ID, 4mm OD down to size that I had around. The washer wasn't going to stay in place on it's own, so soldered it. I hadn't thought of that before, so thanks for mentioning it. If this fix doesn't work out, it looks I should probably just replace the whole crown.
