Seiko 7S26 Mainspring
Don
For those of you who are servicing Seiko 7s26 movements, are you removing and cleaning the mainspring? I've read that the Seiko barrels are difficult to open and maybe not meant to be opened. However, the mainspring and barrel complete seems to be discontinued.
Its a bit tricky to open but it really should be so that the mainspring can be removed, cleaned and lubricated. The barrel lid is not flat but has a side which is a bit different from regular barrel lids. And the lip of the lid goes right down to the barrel teeth.
The lid does come off like any other barrel but because the lip it is quite easy to damage it or the barrel teeth. I usually use a fine stanley knife blade to gently prise it away - the blade should be super sharp in order to get in between the lid and barrel. Slide the blade along the teeth inwards and apply a bit of pressure being careful not to twist the blade. And once you see a gap appearing then very carefully twist the blade, being cautious not to damage the soft metal of the lid or barrel teeth.
The mainspring is also left handed on these movements.
Hope this helps.
    • Ok so there is barely any response happening . After this last attempt i think I'm just going to give up on it because very few seem genuinely interested or even bothered or worried what may happen in the future. ( if someone can set me straight I'd love to hear it ) I would think anyone into watches has heard of Roland Ranfft, how they grew to love and depend upon his site for detailed information. And not just that, he also had a view about Ebay and everyone that visited Roland's site knew exactly what he thought about Ebay, Roland's site also had a secondhand watch sale side to it.  If anyone here could have done anything to preserve his site and keep it exactly the way it was.........Would you have done something to make that happen ?  Its been pointed out to me but not in so many words  that I'm probably coming across as an insensitive p.rick, truly I'm sorry about that, i say it as it is but no malice is intended and yes clearly I'm putting my forum membership on the line here. I'll happily shut up about it now, I've done all i can.
    • Thank you so much for posting this!  Although this movement is serviceable, there are no service notes that I've been able to find.  This is a great alternative!
    • Greetings from another electronics designer & programmer!   I suggest you get a batch of similar scrap movements from ebay - I found batches of Seikos very cheaply, I got seven of one type for £11 (or 11 Euros possibly?). Those were ladies, 4206B I believe. There are also mens movements at a slightly higher price; eg. https://www.ebay.co.uk/itm/134723051997 https://www.ebay.co.uk/itm/235565276549 They are cheap enough so it does not matter what gets messed up or lost & you can probably still get one or two working movements from a batch, even if some part are damaged when you get them. (I've had quite a bit from the guy in Holland, he usually has a good range of movements).
    • Please OH, we should all be proud of our collections what ever they are. If we can't show them off here then we can't show them anywhere. Our favourite gives us a story to tell of why we love it, that story also tells others something about ourselves. These are some of the things that make our forum and our community so amazing .
    • I can take pictures when I am home of what it looks like.  They will be phone picture as I don't have a camera in my microscope yet but I should be able to take a few views to give a good idea of the damage.
