Am I Doing It Right?
bobm12
Hi Robert, I use a lever style opener for that type of stubborn back. Here is one on EBay for illustration purposes. I made my own out of hardened and tempered silver steel and it has been very successful.
http://www.ebay.co.uk/itm/Hot-Sale-Metal-Lever-Pry-Type-Easy-Removing-Watch-Back-Case-Opener-Repair-Tool-/181441111629?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item2a3ebba64d
Hi Geo,
Thanks for the advise, as always very accurate and to the point.
I thought this watch needed to be opened through the front or I was missing something here. Before I damaged it I thought to better ask. The tool you mention is amazing. I got the bergeon one and it opens everything but this watch!
Now I know what to do thank you, and can use more drastic measures... Seiko, the gloves are off!!! :growl:
Thank you Geo and thanks for the -- as always -- good advise.
By the way, I was reading my previous posts in this thread and I believe I need to clarify -- for other readers -- that I was trying to open the back of this watch unsuccessfully using all sort of approved tools in my not small **BLEEP**nal. The reason for this is a broken crystal I wanted to replace as seen in the picture.
I reached a point where frustration made me doubt, and think that the movement was supposed to be extracted from the front (from the crystal side). Luckily we had this forum here to save the day and I was cautious enough to double check -- in this case with Geo -- that indeed this watch opens normally from the back as my original assumption was. I then threw caution to the wind and used more drastic measures to open this watch. A case of a stubborn case I'd say, pardon the pun.
Update:
After opening the back and extracting the movement I found it in a very well preserved estate despite the broken crystal -- and years who knows where -- but very dusty on the dial side. The dial will need a good "fairy" magic -- or as we do on this side of the pond "palmolive" -- to be back to its original looks, as the dust seems to have stuck -- even caked -- to it. A blow with the bergeon pump won't clean the dial. I'm starting to think that in some instances those "B*" tools are over rated! In any case, I have grounds to believe that some of that dust may have found its way to the movement but haven't done a thorough check yet.
Expectations are great and a brown lizard wrist band is also on the way to substitute the existing and worn black lizard one. It will probably go better with the case gold plating despite the black dial.
As an aside, this watch uses a Seiko PC2i movement readily available for about US$20 almost everywhere. So I suppose there is room for error here.
At this point, I'm pondering if I should spray clean and oil the existing movement as per Mark's video on servicing a quartz watch or simply spray it given it is very compact...or maybe use compressed air from a can?
Any suggestions or comments to help me decide -- before I remove my gloves again  :) -- are appreciated!
Robert
Well, I like to finish what I started so I'm getting to a happy conclusion of this thread with a picture. Here is the sum of all my efforts and a small experience to share:
Seiko crystal was ordered from CousinsUK and replaced.
Replaced the battery
AND replaced the back gasket that was pressed into the "pressure groove" and therefore cut by the back when snapping close. It was preventing the watch to be opened!
The dial was cleaned to remove all the dust accumulated through the years in a drawer with a hole in the crystal!
I used a hand held blow pump and rodico mostly since I didn't want to mess with a movement that can be purchased here for about $20 and is still available (I found I have a spare in my quartz movement drawer). It is working perfectly so the fix was mostly cosmetic. Not too glamorous but the picture doesn't make justice to the actual looks of the watch.
I should make a correction to the above post since the movement is a 7N43 not a PC21 but I was fixing another watch at the time and got mixed up while writing this thread.
Many quartz movements are very cheap, to the point of not worth overhauling the movement. It is a lot quicker (and cheap) to simply replace the whole movement. Once the movement is replaced with a new one, I found that the old movement is excellent to be stripped down as a practice for a beginner like me :)
    • Drilling is going to be difficult, firstly because the drill bits are so thin and brittle, expect to break a few. The second issue is access to the 'hole', as the other lug will be in the way, meaning that you will have to drill at a slight angle, putting a bending stress on the drill bit and with the slightest drop in concentration .... and back to my first point. I would be tempted to grind them flat with a Dremel type tool or small jewelers file, and then put a center punch in the center of the bit to be drilled so the drill bit doesn't skip around and break... but expect this to be slow and frustrating work. By the time you have done 4 of these you'll be an expert and can come back and tell us all the best way to do it if you go down this route. However, I would seriously consider What @watchweasol said and drill from the outside-in, this will ensure straight holes without having to work around the other lugs. It may be worthwhile making yourself a simple paper template so you can be sure to match the position of each hole before drilling. In the end you will be left with 4 holes on the outside of the lugs, but many cases are made this way and unless you are looking for it you probably won't notice or realise that it's not the way the watch was meant to be in the first place.
    • What works for me (waiting for the villagers to assemble with torches and pitchforks) is to put a liberal (in watch terms) spot of 9010 on one of the pins of the pin pallet, this seems to improve amplitude and beat error.
    • Non-magnetic is a poor description of such a hairspring. A better description would be unmagnetisable hairspring. There are metals and alloys that are attracted to magnets, but don’t become magnetised themselves. A hairspring made out such a material will be attracted to magnetised tweezers, but will not become magnetised. These hairsprings can be disrupted by being in close proximity to a magnet, but the disruption will cease the moment the magnet is moved away. These are hairsprings that could conceivably be disrupted by a magnetised hairspring stud. Best Regards, Mark
    • More than enough. Here's mine at the height I work at. I think the working distance with the included 0.5x Barlow lens is about 9".   So yes, that halves the magnification. The full story is the objective lens goes from 0.7x to 4.5x. The eyepieces are 10x, giving you the advertised magnification of 7x-45x. However the working distance is unacceptably short, so it comes with an 0.5x Barlow lens, reducing the magnification range to 3.5x-22.5x, but giving you a good working distance. What I did was buy a pair of Extreme Widefield 20x Eyepieces for when I need more magnification. You keep your high working distance, but get your 45x magnification back, at the cost of some width of field.
    • Modern ones after blue steel, invar, elinvar and nivarox , the shiny one are not supposed to become magnetised. But i have had them jump to tweezers. And i dont really understand the comment that what can be magnetised is the stud carrier and rate regulator and they can attract the hairspring ? If the hairspring is non magnetic then how can it be attracted to something else thats become magnetise, its non magnetic , that doesn't really make sense to be ?
