Hi folks,
I measured up the mainspring in a Waltham model 1894 12s and came up with (in mm)  2.10 x 0.14 x 490 or so mm, hole end, with 15.5 barrel ID.  For a few dollars at Cousins, I can get a 2.10 x 0.15 x 480, 15.0 ID, TR end.
Otto Frei has a factory mainspring for this watch that they are saying is 2.15 x 0.16 x 19 1/4 in (488mm) with end hole, for about 4 times the cost.
One thing I'm sure of is that I might need a better quality set of calipers :D. With the variability in sectional area between the springs, can I expect significant differences in power delivery, or negligible?  Thoughts?
StuartBaker104, this is a great read and is definitely dusting off some old engineering concepts that I haven't played with in quite a while!  What an excellent site, thank you very much indeed.
C
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
