Finally well into my reassembly but lacking confidence/skill with placement of the balance assembly.
Finding it difficult to ensure the balance pin jewel is properly located in the pallet fork. Can't see to guide it in.
If the balance wheel doesn't rotate sufficiently I presume the pin is not properly in the fork?
Studying Hacko helps. Mark's video just shows a quick drop-in and there she is, if only I could do as easily??
Any advice welcome.
You are correct in this assumption.
Check position of pallet fork, if banked to left or right, (looking at movement from side), it may be the  pin jewel position when you are trying to fit is opposite of fork, Seikos are pretty tough to see alignment, just not enough space! Also check position of pin, before insertion, is it aligned to position of fork? Hope that helps.
If jewels are installed, watch is wound and the balance does not oscillate when fit in, then impulse pin is not on the fork. In that case with the cock screw removed, feel in which direction the balance does not turn. Lift it a tiny bit, move further in that direction and let it go. Impulse pin should now be well settled and balance moving.
    • What size is the movement and have you done the usual search with bestfit. To me it looks like something in the 10 series. The other option would be to measure the staff and try and trace it from their, or at least find an equivalent.
    • 1mm copper wire can be tapered to fit. Softer than brass but it does work.
    • You would think so.....but maybe not. I did just that with a 50's Oris tank. 5 years ago.....stripped and polished...it hasn't tarnished and looks exactly as it did..I wear it often. Looks like brushed gold plate.
    • This poor watch now has a new escape wheel jewel. I got a jewel assortment and found one that fitted snugly in the setting, and whose hole was a neat fit on the escape wheel pivot, glued it to the flattened end of a 1mm drill bit and turned it on some brass with diamond lapping paste to give it a taper on one side. I used a sewing needle to gently close the setting over the jewel. It doesn't look too bad in the pic, but actually about the bottom third of the setting has nothing left holding the jewel down and I'm not sure whether it will hold. I'll have to see when I reassemble it. Before I reassemble, I thought I'd better have a look at the balance and check its poise. I put it on a pair of tweezers and found it did indeed want to always stop with the same point uppermost, swinging to and fro around that point. While I was thinking about timing washers and that I don't have the right tool to remove a timing screw, I noticed that one of the pivots didn't look straight. A closer look was called for: The right hand (upper) pivot is definitely bent. So, should I try to straighten it? It is likely to break, I suspect. Am I going to be able to buy a replacement balance staff for a watch more than 100 years old with no movement number? Seems unlikely. I have no lathe so I'm not in a position to make one myself. What are my options?
    • Here’s is an update on the watch. I haven’t worked on the watch since, but I seems like the watch is now running perfect if he don’t wind it fully up. If he just wind it almost fully up, it doesn’t seem to stop.. and it stops after some time if he wind it fully up.
