Manual of American Watch Movements
adiorio110
Hi Busakaz
I am not really sure if this is even what I need. I have a Waltham Model 1877 18s Appleton Tracy with broken Escape Wheel pivot. I am looking for the part number and perhaps cross reference numbers, or other models this part may be available in. I think I found a catalog which gives me part number.  Looks to me like 948 is wheel alone. Numbers 949 and 950 are slow train and quick train parts Not sure which one I need. What Should I look for? Below is a picture of what I need to replace. I will save this part for a later date when I take a shot at pivot replacement.
Is this basically what The other Manual of American Watch Movements has to offer as far as Waltham's go?
Here is a copy of Catalog I found in case another beginner can use it.
Catalogue of Waltham Watch Materials
https://1drv.ms/b/s!Ah-hqgUuod3u2BtzKv62JXoPuLbL
Thank You
Anthony
2 hours ago, adiorio110 said:
MY Bad
Looks like this is open face configuration so it would be 951 and 952
My book doesn't list that movement number it only lists 1883,1892 in size 18 and all part numbers have 4 numbers not 3, let me know if I can help
regards kaz
45 minutes ago, adiorio110 said:
If there are only two choices one must be the default
Sent from my SM-T580 using Tapatalk
1883 model
escape wheel only 1304,1305
escape wheel + pinion 1308,1309
1304 has 15 flat faced teeth
1305 has 15 round faced teeth
flat faced teeth uses round faced pallet stones
round faced teeth uses flat faced pallet stones
that's all it says for that model really.
Ok I purchased a donor watch with the escape wheel I needed. Both watches are model 1877 but different classes. The escape wheel pivot from the donor fits in the bottom plate jewel but the pivot is to big for the top plate is it customary to trim the pivot to fit  or replace jewel?
There always seems to be an issue with watch repair. It just shows you how much you really don't know every step of the way.
