hello everyone ,
i have a problem with my oris. i need to replace the pipe because its bent and the pipe is very large in diameter as well  (its 3mm) i cant even find a replacement crown for it.  , now i have no idea how to do it and where i can find a replacement pipe and how i can fit this new pipe on my watch case.i want to replace it with a screw-down style crown.
can anybody help ?
If you know someone with  a laser welder you can fit it with a 7mm rolex type crown, you may have to fit a tube to the case to make it fit.
With that done you can tap the tube to fit a rolex type screw down crown 7mm.
You can get tubing from any good material house,
good luck
