Bizarre state of the balance! Miyota 8200
I hadn't realised how cheap you could pick one of these up for as my first thought was a new 8205. @SamLiddle Don't know where in the world you are but you're better dealing with them through eBay. https://www.ebay.co.uk/sch/57720/i.html?_dkr=1&iconV2Request=true&_blrs=recall_filtering&_ssn=speedtimerkollektion&_oac=1&_nkw=citizen+miyota+8200
Found this on speedtimerkollekion, I think they ship cheap in Europe. https://speedtimerkollektion.com/product/182124
that's how I've always done them. Start at one side and work your way around feeding the edge in with your fingernails. If you hit a spot that won't enter, check that the edge isn't getting damaged, if so remove and feed that bit in first. if it's really tight you may need to reduce the size very slightly. -
Many thanks all. I'll have a go at straightening the hairspring, for my practise really. I expect I'll be sourcing a donor movement anyway as I need an escapement and pallet fork anyway. Will update.
Dr bonefixer are you serious ? A true watch repairer never throws any scraps in bin, there are many good parts in OP's watch. This has saved me plenty of $ . Regs
