Setting Hands On 7750
But you'll need to make sure the end of the old spring with the stud is long enough to enable you to bend the new spring over it. Movement is already sorted as a Frey/Freco Ancien
What is the movement? Did you fit a dial washer ?
Glen, I've only just seen this, if you haven't already , lets have a go at identifying this movement. I have a few different catalogs that often successfully match keyless works parts. -
By RichardHarris123 · Posted
By watchhammer · Posted
This is probably correct thinking. Again, many people much more knowledgeable than myself on here. Maybe it's best to buy a cheap lot of very broken watches just to practice screwdriver and tweezer work for a while then clean the Benrus? I dont want to give bad advice because I'm nieve/novice, but I think some times you just have to dive in and make some mistakes.
