Seiko 6105 crown gasket service
Just thinking about this and with it being bent you could be measuring slightly under so could be a 10 not an Ancien. The roller table dimension should answer this.
The cost factor really isn't an issue. If you doing this as a hobbyist in other words you don't have to please a manufacturer or a customer then you don't have to worry about the expiring date providing you keep your oil in a cool dark location not a cold location just out of the sun and the lubrication the synthetics should last Almost probably forever. The biggest concern typically for watch companies with long term storage is contamination of each time you extract oil out of the. Then what is your definition of it doesn't work and you'd have to service the watch again?
Look at the size of the screw head compared to the thread size. It doesn't take a lot to sheer off the head from the thread possibly leaving the thread embedded into the barrel arbor. That would be bad.
They're available from Cousins but appear to be a one movement only part. I've got a selection of stainless steel tube. You'll also need to support the other part of the shaft to make sure you're only bending the pinion.
Its risky but sometimes do-able. I showed a technique in one of my old videos... Go to 0:46 (46 seconds in).. Be very careful Hope that helps.
