Dubois Depraz chrono module - help!
The more “niche” a topic is, the less likely the accuracy of an AI output. You can do a reality check before sending your prompt by doing a quick Google search. If relevant info is scant and you are already familiar with the sources, skip the AI. But if you get pages and pages of results, give it a try but verify what you can. Skilled users sometimes feed the responses from one AI model to another on an unrelated platform for fact-checking, and ask for specific sources when available.
Thanks John, I'll try a new circuit as well as lubricate the movement.
Sorry if anyone feels I reacted incorrectly, thinking is a timely, healthy discussion about the limitations of AI but less so about Rolex real vs fake. There’s good information on that, too…thank you…
I have the rubber ball and the 3 finger dish type of remover but it wouldn't budge. I did hold the compass legs right down near the points so they are ok. Never come across this type of caseback before. Also never come across a Rotary with an automatic movement which doesn't say so on the dial....
Solved it!!!!! A post on the underside of the operating lever return was sitting on the wrong side of the spring. Due to the design it worked a bit, but not properly. Refitted the lever while retracting the spring and now it does what it should! I think you learn more if you solve a problem yourself rather than being told the answer. Now it's back in the wash, and see if I can get this thing up and running!
