Issue with Seiko 4006 Barrel Arbor and Mainspring Fitment
For third and escape wheel upper cap jewels i use seagull 1.00 x 0.14mm (J66703 from cousinsuk) in 7s26 and nh3x movements. Shock spring is 015.703.
So you apply the Fixodrop after oiling? How do you apply it? Thanks.
I wouldn't say it's super easy. A correct size mainspring winder is needed and leaving the T end out of the winder is the trick to get it in. Not the easiest thing for a newbie. -
By TimepieceTinkerer · Posted
Apparently this the case. Thanks Update on Seiko 4006 Barrel Arbor Issue Just a quick update for those who kindly offered their help—thank you again! I’ve now confirmed that the issue was due to an incorrect barrel arbor. I ordered the Seiko 213.805 barrel arbor from Cousins (part number SEI213805), which was listed as compatible, but after comparing it closely and contacting Cousins, they confirmed that the part was not correct for the Seiko 4006. It turns out the wrong item had been listed or picked. That explains why the arbor didn’t seat properly or extend far enough to hold the barrel assembly securely. I appreciate everyone’s input—it really helped me think through the problem more clearly. Thanks again for your support! TT
