I am working on  the crown of an EMG DL63. The stem snapped and there is nothing to grab.  As a last resort I was successful in drilling a hole in the middle of the broken stem.  I was planning to epoxy the filed eye end of a bent needle in the hole to see if I can remove the stem (see first attached image).  Now I know this is likely not going to work, but what the heck it is a last resort.
Anyway, as I was heating the crown to release the locking agent my heating plate seems to have malfunctioned and heated up to almost 500C before I noticed and this resulted the chrome to yellow (see second image crown color in comparison to the first one).  Am I right in assuming that I can try and reverse the discoloration by buffing it with a little metal polish?
And in case the discoloration removal or stem removal does not work, where could I find a replacement crown?  The crown has a a distinctive lock symbol on its face that I would like to keep if I need to get a replacement.
Further I am looking for the size of the two gaskets that are in the crown.  I was initially unsuccessful in removing them and I had to soak the crown in acetone to remove the gaskets.  I measured the sizes in the third images.  Can I assume that is the size of the replacement gasket?
thank you
claudio
This is a modern watch, the crown is definitely made from solid 316l steel. You must have heated the crown to some 200C caused the surface colour to change to light yellow. It's similiar to steel tempering. Yes it is the chromium oxide that forms during the heating that gives rise to the colours you see as you know stainless steel contains chromium. The fact the crown is SS lead me to a question, you've never heard of the alum method? Because alum would work perfectly in this case, instead of drilling, which, there is always a risk of damaging the crown, I would just let the crown chilling in some warm alum solution for 1-2 days and the job is done.
Sure can but the thing is the crown is not just mirror finishing, the lock symbol is polish while its background is some sand-blasted finishing so it would be hard to replicate that. You can buff it all shiny but losing the sand-blasted finishing means it won't look exactly like before.
Gasket is always tricky to me. I would try to use some gasket that look closest to the broken one in term of thickness and diameter, and check if the replacement gasket fit with some friction to the case tube.
Lastly you can still use alum at this point.
Edited by ColdWind
Typing errors
Thank you ColdWind,
I did try the alum solution and albeit slow (I am on my third bath of 6 hours at 70° C with a solution of 10ml of water and 2.5g of alum) it seems to be working.  I can now screw in the new stem, at least a few turns.  I expect that at some point I will be able to screw the stem in all the way.  Perhaps next I will try a bigger bath.  I wonder if the limited amount of alum is slowing down the process?
An happy side effect of the alum bath is that it removed the oxidation from the crown!!
claudio
