Pallet Adjustment Help....
DJW
I'm working on a Hamilton 917 and while testing the functions after reassembly I noticed that the escapement is showing a fault.
While checking the pallet operation on the escape wheel, I noticed that about 3-4 times per revolution the pallet fork will not snap over to the entry side banking pin. Usually when I check the locking and unlocking of the pallet, the pallet will snap from banking pin to banking pin with just the slightest touch of the tweezers. This pallet (Only on the Exit Stone) with release the escape wheel, but not snap over to the other banking pin. The escape tooth entering the pallet hits the entry stone on the face and forces the pallet back to the exit side banking pin without first locking on the entry pallet stone.
To narrow this down to the pallet and not the escape wheel, I swapped out the escape wheel and the same thing happens.
I swapped out the pallet with another and the problem disappears. So I'm confident that the pallet is at fault, but I'm not sure which pallet stone to adjust. I'm thinking the exit stone should be pulled out a bit, but I'm not 100% sure....
Any ideas on what I should do?
Thanks!
Edited by DJW
I really tried but all I have is my phone! It's just not working... I can say that it does appear that the escape teeth are hitting a lot shallower on the entry stone as opposed to the exit stone, quite a bit actually. Maybe a little more than half as much? Does that make sense?
So maybe the entry stone is not out far enough to catch the tooth?
BTW, I installed the balance and it seems to run quite well regardless!
I'm getting 300+ amplitude in every position (I did install a new mainspring).
Try it on one third wind - if it is stopping then you need to remedy the pallets, possibly by adjusting the lock.
If you are getting a nice 30 hours out of it on a full wind and it's keeping time, then I would not go to the trouble. 300 is a good amp. This is why I like the timing software from Graham Baxter (Google it) as you can leave it running all night and then check the graphs in the morning and see what gremlins you can find :)
OK, so I checked the watch on just 2-3 winds and it runs fine and does not stop.  Although it really bugs me that I know there maybe something out of adjustment, I guess I won't worry about it. I'll check it in the morning to see how it's running.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
