Hi all ,just received a Respirator TV style that requires a service.I note the spring retainers on the inside of the lugs.How does one hold the 4 retainers in the depressed position to allow release of the case from the movement.Does anybody have some advice or instruction to share?
1 minute ago, tomh207 said:
Pictures would be helpful, it doesn’t sound like a common way to do things.
Tom
Will post pics thanks Tom
Look carefully either side of the lugs ,small spring loaded dark pins that can be depressed inwards towards the movement
The case and crystal must be removed to access the movement,the winding stem and crown will remain attatched
No the case has a recess below the stem to lift the entire crystal and case and reveal the movement in the case back
Here is a link that shows the same case on an IWC watch
