1 hour ago, mikepilk said:
I only watched the start, but he's out on magnification by a factor of 10. It's 7X to 45X, not 450X
Oh weird! I saw this video months ago and made this exact comment on it. Or at least I thought I did, because I don't see it.
I noted that at 450x you'd be able to see individual blood cells.
I would guess a simple mistake, I took it he meant 45, any thoughts on the scope?
2 hours ago, Chief said:
I just watched this yesterday! Making me jealous! I'm still using a loupe wedged in my eye socket 🤣 definitely putting one of these on my Christmas list
Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
How do you find the working distance from microscope lens to movement? Is it comfortable enough to get tools in?
More than enough. Here's mine at the height I work at. I think the working distance with the included 0.5x Barlow lens is about 9".
So yes, that halves the magnification. The full story is the objective lens goes from 0.7x to 4.5x. The eyepieces are 10x, giving you the advertised magnification of 7x-45x.
However the working distance is unacceptably short, so it comes with an 0.5x Barlow lens, reducing the magnification range to 3.5x-22.5x, but giving you a good working distance.
What I did was buy a pair of Extreme Widefield 20x Eyepieces for when I need more magnification. You keep your high working distance, but get your 45x magnification back, at the cost of some width of field.
I agree, game changer. I watched Alex's video as well. Another thing to consider is the adjustability of chair to bench and the head of the scope so that at max height is not above your eye level. I got the trinocular port for the camera but did not get a good enough camera and have not figured out how to run it though my laptop to make videos or just take stills through the scope, yet.20231029_0947003.thumb.jpg.729e431e723040e3847dced6ffb209ad.jpg
Get a couple of elbow pads, these are inexpensive and have sticky back, but I don't have them stuck down and can move them around.
Chair height is not usually an issue unless you under 5' 2" lol.  The thing to watch out for is a draw in your bench above your knees.
Whats your field of view with these please msb ?
At the lowest magnification, I can just get all of a normal wristwatch size movement in field. For some things it's too much magnification, but the nice thing about the eyepieces is they only take seconds to swap in and out.
I'm genuinely surprised I've never read about anyone else doing it, to be honest.
I think maybe we're all a bit dim @ManSkirtBrew 🤣
99% of the time I'm working with the 0.5X Barlow, so mags from 3.5X to 22.5X. When I need a close up of a pivot or jewel, I take the Barlow out, and even put in the 2X Barlow, but it's a nuisance.
So like you, I had that D'oh moment, why don't I just use 20X eyepieces (WF20X/10). They take seconds to change, and you keep the working distance. The only downsides are lower field of view, and less brightness.
Does anyone use the x5 eyepieces,  when i use them on my different amscope , the magnification changes to x5 but the field of view remains exactly the same as the x10, so nothing gained. The optical lenses can't be swapped out or at least they are not available as far as i know.
    • Speaking of 404 reboot.... I have another category of watches... Those that I wished I had not gone above £4.04 when I bid for them!!! Someone probably should have also told me to stop before I put a new stem, crown, crystal, escape wheel and then adjusted the end shake on the escape wheel. This was all on watch that had a EB 8800 pin lever movement in a worn gold plated case with a snap on case back (basically everything I try to avoid!).
    • The problem is that this movements were not produced with the modern level of standartization, there for parts from one didn't fit well to another, even if they may look the same. May be it doesn't concern the winding stems, but yet there are not spare parts for such movements in supply companies, not even clear calibre identification possible. And where calibre identification  is possible, there are no Ronda numbers for the balance staff or the winding stem for this calibers in the data bases.
    • That black stuff - I had similar things happen with evaporust!  In that case I understand the evaporust eats the iron oxide away without hurting the metal but it can leave behind a layer of carbon which was in the steel that got oxidised. I spent ages trying to perfect a cleaning regime with various different stages in jars in an ultrasonic bath. In the end I switched to washing all but the balance and pallet fork in IPA and gently brushing it with a small artists brush.  I would estimate that I have found an extra 20º of amplitude doing this! It also takes me no longer than waiting hanging over a tank to move stuff to the next jar If it is really bad then I have used the IPA as a prewash and go through my old routine
    • I thought is FHF. Sounds good to make winding stem by myself but I am not in watchmaking on this level. 😄
