400 day clocks
dnhb
Most of the torsion clocks I have worked on came to me with replaced torsion spring and for some reason, the spring appeared not correct for the movement (or the pendulum) and the period of oscillations differed from needed one and was impossible to compensate by pendulum regulation. I actually never asked how and why, just figured out and developed a way to solve the problem using the existing springs, no mater if they were thicker or thinner. I have used piece of hairspring from chinese 'Shanghai' alarm clock in 2 cases where the torsion spring was missing complitelly, with the needed correction to obtain correct preiod. I have never ordered springs - in the past it was not possible, and later - it was not needed as I have the solution in my drawer...
On 4/1/2024 at 8:39 AM, Dell said:
The most important part to get thinned is between the top block and fork as this is the bit that does the work.
Dell
Thanks to your advice Dell I've got the clock running, apparently reliably (time will tell!) and it's back for sale in the Charity Shop (they've put a £40 ticket on it). I'm still in the process of regulating it in situ - initially fast by ~5 mins a day & waiting to see what effect one complete turn of the '+-' wheel has. Looking back over the experience I can see I hadn't appreciated just how delicate these torsion springs are and have been lucky not to break this one although I have manged to kink it at both top & bottom when fitting/removing it from the 'blocks'. On this basis, it seems that one answer to my earlier question about what causes the need for the top block housing to be turned left or right to get it 'in beat' is how 'true' the spring is & the angle at which it emerges from the blocks if not exactly 90 degrees. I also found that I needed to shim one of the movements supporting pillars. I'm very grateful for the interest you & others have shown in my little project.
On 3/31/2024 at 6:58 PM, nevenbekriev said:
I thought I am the inventor of thinning torsion springs... My advice is to use this kind of tool to strain the spring in order to avoid the risk of curling it.
Then, just piece of grit 1000 sanding paper needed, folded in two with the sanding surface inside. Squeeze it between fingers and slide it on the spring 2-3 times fully from one end to the other. Then try the period of the pendulum. !!! it is easy to overdo thinning and make pendulum too slow !!!
That seems a good idea Nev. Unfortunately I didn't have such a device to hand but will look out for one for future use - time-consuming (not to say frustrating) though working on this 400-day example was, I haven't been put off addressing another one should the occasion arise....
Edited by dnhb
    • I'm just about to clean the parts of a Cal 684 which has a similar Winding Gear (#1464). I plan to clean it in my usual way (ultrasonic with Elma solutions) then dip in Lubeta V105. As for Epilame. The only parts I'll be treating are cap/pallet jewels and escapement wheel. I'm not splashing my precious fluids all over the place !
    • Yes it sounds as if the gut has fouled up. If the clock is not level that can cause the gut not to wind onto the barrel . You need to take it out of its case and post some photos. The type of key for these clocks are crank keys.
    • This guy unites the two reverse wheels in the usual system of winding movement. Do not take it apart, thow takin it apart is possible. You can get lost the small ratchets inside. I wouod use pure petrol to clean it ahd will rotate for some time the wheels when holding the pinion untill the guy is diped in the petrol. Then, after epilaming (if any aplied), I would use some Moebius 8000 solved in pure petrol and put a drop on the wheel, then will blow with air and let the petrol dry. This is old recepy not from Omega manuals where I have no idea what is the procedure.
    • This is to prevent the stone on the other side from breaking when canon is pressed. You can put the canon before assembling the movement, but this is if the 3th wheel when in place will not prevent the other wheels to get in place. The other way is to assemble the train and then to put the movement on something that the pivot tip will lay on and thus the pinion will not press the stone when canon is installed.
    • My experience with this Vertex is to unscrew the ring towards the back, with a screwdriver on the slot.  The Crystal can then be pushed back.
