Chelsea ships bell strikes incorrect sequence
Updated photos with new leather strap and original signed buckle. I like the minimalist strap - plain back with black thread...
New strap pictures. This one is going into the collection. Will be looking for a president bracelet I think ad well...
Stems are cheaply available on Ali Express (link) or eBay, as for the crown, it may be easier to harvest one from a donor movement rather than just buying a crown. If its just a matter of it unscrewing itself as @RichardHarris123 is asking then blue loctite is your friend, I use the blue medium strength non-permanent version for crowns, which they also do in a stick (like a glue stick) you just poke the stem thread into the blue semi-solid goop and this leaves enough on the thread to do the job without having to worry about excess fluid. Note 90 AED is about £19.00, but it may be cheaper where you are from
By Michael1962 · Posted
A photo of the crystal in the case from the top would really help @B1N9S
